Just started yesterday! ICE does not like to RUN
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zardoz, Jul 9, 2015.
  1. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    We have owned our 2008 Prius since new so when it misbehaves we know it.
    Starting yesterday, when accelerating from a stop light we would be on electric ONLY. The ICE would not even TRY to start. There were NO fault lights or other indications. Then the ICE would run a bit and stop and sometimes begin to act almost normal. We watched the HV battery charge go from 3/4 to one bar in a matter of minutes.
    We limped it back home, the ICE was running so we let it run until the battery got up to three bars and he ICE shut off. Then we got in my 05 Prius and finished the task at hand.
    Last week Toyota had to replace the electronic control valve (about $500). I wonder if they left a connecter loose somewhere... I looked around under the hood and did not see anything out of the ordinary.
    Any suggestions would be appreciated!
  2. JC91006
    16,827
    8,600
    Miles on the car? Have gas in it?
  3. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    Miles on car 170,000. 3/4 tank of gas.
  4. Mendel Leisk
    41,901
    I'd get it back to the service dept without delay; your suspicions about something disconnected (by them) sound very plausible.
  5. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    Update. This morning we set out to drive it back to Toyota. Car is running fine. Not good I am sure this problem will come back at the worst time.
  6. bisco
    52,390
    i hate when that happens. it's like your puppy knows you're taking him to the vet.:cool:
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    my 05 drops from 1 green to 1 purple within a few mins with the ac on sitting at a red light, recharges quickly.. traction battery rebuilt, 12 volt battery good, im starting to think its an issue with the ac compressor like a dead short..ac off the car is fine all day long..
  8. strawbrad
    953
    1,007
    First, go buy a Mini VCI cable. You own at least two Prius. The cable costs less than $25. A Mini VCI cable and Toyota's Teachstream software will bring you into a world of knowledge and enlightenment. Without the cable you are in the dark hoping a dealer will light your way by burning all the cash in your wallet.:oops:
    I can not think of any Prius part called the "electronic control valve" So, what did the dealer replace and why? That is at least a hint of where to start.
    Brad
  9. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    Sorry for my imprecise language: "REPLACE COOLANT FLOW CONTROL VALVE ASSEMBLY (CODE P1121--COOLANT FLOW
    CONTROL VALVE STUCK)". The part cost me $479.98.
    Our Prius' have been so reliable that I have not been online all that much as of late...
    Where do I obtain Toyota's Teachstream software and for that matter the Mini VCI cable? It sounds like the way to go!
    Jim
  10. Beachbummm
    1,160
    392
    ebay or amazon sells them BUT they are counterfeit copies of the software so use an old laptop as they have viruses, it will run on xp or windows 7..got mine for under 25 bucks free shipping
  11. strawbrad
    953
    1,007
    That valve controls the coolant flow into and out of the thermos storage bottle. The idea is that the stored hot coolant can help heat the engine up quicker. I drove my own car for about a year with that code active. It is not something that can disable the car. Replacing the valve requires the coolant system to be opened so some coolant will be lost and some air will get into the system. You should check the coolant level in the radiator overflow bottle. Air in the system "could" goof up how the engine runs.
    The Mini VCI cables can be bought on Ebay or Amazon. The sellers located in the US tend to be a little higher on price, but you can get the cable much quicker from them. Techstream software can be purchased from Toyota. Most of the cables come with a hacked copy of Techstream and it can be downloaded also.
    Brad
  12. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    Dumb question... As I am about to purchase the cable... 16 pin or 22 pin connector?
    Thanks!
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Which ?
    This sounds like a calibration issue; as in, the car does not know how energy is in the battery. I suggest driving some more and see if the car sorts itself out.
  14. strawbrad
    953
    1,007
    16 pin. You can get the cable quicker from US based sellers. They generally cost a little more.
