Just Test Drove A VOLT!!!!!!
Discussion in 'Chevrolet Volt' started by just_older99, Jun 19, 2011.
  1. Trollbait
    12,826
    It depends on how long and how often those long trips are. For the people who have already gotten Volt, about a third of their miles is on gas. If they had gotten the currently available Prius, they would have burned twice much gas.
    The premium fuel requirement is CYA for GM on warranties. They couldn't trust people to add fuel stabilizer, and turning on the engine too often defeats the purpose. The Volt has knock sensor, so if you did take it on a long road trip. You should be able use regular when you do.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Ok, but Volt has 12x more battery capacity than Prius (16 kWh vs. 1.3 kWh). 12 Prii can save 6x more gas than a single Volt.
    The other fundamental difference is, Volt require external energy (electricity) to save gasoline.
  3. oldasdust
    oldasdust Member
    356
    47
    illinois
    Saw one up close today at a county fair. Looked nice outside and interior but out the door cost over 45grand no thanks. I'll take a 2012 prius plug in any day for thousands less and can criss cross the country any time i choose.
  4. darelldd
    6,059
    389
    Northern CA
    Nicely said, BTW. I have gotten much the same from many Prius drivers in regard to BEVs in general. They're unproven. Too expensive. Little cars. Can't go fast enough. Battery won't last. Battery will be expensive to replace every two or three years.
    And here I am after nine years of driving on sunshine in my little SUV with the original batteries wondering when all these terrible things are going to happen.
    2 people like this.
  5. daniel
    14,487
    1,519
    Spokane, WA
    People don't say that to me any more. ;)
  6. coach81
    coach81 Active Member
    758
    116
    Louisiana
    The price of the PHV came out today .. OOPS :eek:
  7. gwmort
    gwmort Active Member
    985
    211
    Delaware
    I was going to quote the same passage. $45k for the volt is pretty loaded, but with the bigger tax credit comes out almost identical to the PHV advanced ($37.500 more or less).
  8. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    the difference should be clear...it's still a GM product versus a Toyota.
    I'm just saying...no WAY GM trumps Toyota reliabilty with one 'souped-up' hybrid.
  9. gwmort
    985
    211
    Delaware
    I understand and never said anything trumped anything. For many months I've heard about how the PHV will be so much drastically less expensive than a Volt, but its just not.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's not the way it was stated. The hope... for both plug-ins... has always been to make that "nicely under $30,000" goal we heard countless times over the years.
    Volt's MSRP of $39,995 isn't even remotely close to that.
    PHV comes way closer at $32,000 and is indeed drastically less expensive.
  11. gwmort
    985
    211
    Delaware
    What was stated to me many times was that the prius would be $10,000 cheaper, and its only three.
  12. Joe E. Sheldon
    Joe E. Sheldon New Member
    SoCal
    $39,995 - $32,000 = $3,000 ??????
  13. gwmort
    985
    211
    Delaware
    $39,995 - $7500 = $32,495
    $32,000 - $2500 = $29,500
    $32,495 - $29,500 = $2,995
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    The two are not comparably equipped. Prius PHV is a midsize and comes with a standard charger faster than Volt with $1,500 fast charger.
    It is more appropriate to compare with a fully loaded Volt instead. The difference would be $8,000.
  15. oldasdust
    oldasdust Member
    356
    47
    illinois
    The volts i have seen are over $ 41,000 msrp. I have no idea if they are fully loaded . At that price how does the volts equipment compare to the base and advanced phv ? Also insurance costs and residuals would factor in if i was compairing the two.
  16. oldasdust
    oldasdust Member
    356
    47
    illinois
  17. mfennell
    mfennell New Member
    241
    39
    You say a lot of things that are opinion, but this constant refrain is simply intellectually dishonest and you know it.
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Prius PHV charges to full in 3 hours using a standard included charger. Volt charges to full in 4 hours with the 240v fast charger.
    What's dishonest about that?
  19. stephent
    stephent Junior Member
    27
    What's dishonest about that is the number of EV miles you get is vastly different. One could plug a Volt in with the 120v charger for 3 hours and also get the same 13-15ish EV miles out of the charge. It's not an inherent advantage to have less EV range! You come home and park the car for 10+ hours while you sleep, how how does the Prius being done after 3 hours help you in any case? You have a lower electric bill, sure, but EV driving is way cheaper and more efficient than gas, so this isn't a good tradeoff!
    The smaller battery gets you lower cost, and preserves more of your cargo space, for those who care about those things, but the faster charging from empty to full is not an advantage, because you aren't getting more miles per hour of charging.
  20. mfennell
    mfennell New Member
    241
    39
    Fixed.
    The 6th graders defense. It is intellectually dishonest because it specifically omits contextually relevant pieces of information (range, rate of charge) to declare one better than the other.
    But you know that.
    At this time, there is no evidence (save the info directly from the Prius team that the PHV has a lower MPGe rating than the Volt/Leaf but frustratingly few details) that either car charges faster than the other in the actual important sense: EV miles over time. Since they use the same amount of current, give-or-take, there's no reason to think they'll be notably different.
