Just the INFO display is not working
Discussion in 'Gen 2 Prius Audio and Electronics' started by Danno5060, May 31, 2023.
  1. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    For some reason, my 2009 Prius Info (the screen that shows the current MPG and recent history) is blank.
    The Climate, Map, Maintenance and other displays work normally, but the Info display is totally blank.
    Weird.
  2. BrokenPipe
    BrokenPipe Junior Member
    34
    NorCal
    What voltage do you measure on the 12v battery? If it's low it can lead to strange things.
  3. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    A lot of people make this claim but have no evidentially based facts to back their claim. What information do you have for us to support this claim?
  4. BrokenPipe
    34
    NorCal
    Did you read the original post?
    All the modes that are working, don't depend on the car remembering the mpg since the the trip / odo button was reset. The only screen that's not working needs to remember the past history. If the battery is low, it can forget everything if you power off the car and voltage drops too low.
  5. dolj
    dolj Senior Member
    8,652
    4,403
    That doesn't answer the question posed. What consistitutes "low" and "too low"?
  6. Danno5060
    405
    209
    Wyoming
    I think I answered my own question. Thanks for the suggestions though.
    It's not the auxiliary battery. I changed that out a couple months ago. For a car with over 210,000 miles, it's really in remarkable shape. I'm always amazed at how much the car is working like it actually should be. Up until this one, my cars have been literally falling apart by the time they're at 130,000 miles or so. But then again, I've usually had *brand name censored* vehicles.
    I called it the Info display because that's what the button that I usually push on the steering Is labeled. That particular screen is actually titled Consumption. Hitting the Info button next to the display brings up the Information Menu display, not the Consumption display. From the Information Menu, I found I had to select the Trip Info item to get where I wanted to go. After all the years and miles we've had this vehicle, I'd forgotten how to get into that particular screen, and it's not obvious.
    Having this problem makes me sound like a Prius noob, but my wife and I have driven this car for about 150,000 miles. I've also got a Gen 3 we've driven for about 80,000 miles. The steering wheel buttons are second nature. Calling up that particular screen, (which is about the only one we really use) using the alternate method isn't straightforward, or obvious because of the different names. I'm not a tech noob here either. I've programmed industrial control systems and SCADA displays. Calling a display by three different names - Consumption, Info, and Trip Info is something I wouldn't do on the systems I worked on..
    Here's the real issue. It seems like I'm losing the buttons on the steering wheel. The only one on the right side that seems to be still working is the voice command button. I'm sure there are a few threads some cable or connector that goes to the steering wheel buttons that I need to fix. When the button I normally push to bring up the "Consumption" display didn't work, I had to find an alternate route to that display. Hence the looking like a total Prius noob.
  7. bisco
    52,878
    low is below normal, and too low is below operating parameter
  8. dolj
    dolj Senior Member
    8,652
    4,403
    That catches us all out at some point. I'm glad you got it sorted.
    The part that fails is the cable called the clockspring. There are quite a few threads on replacing that. Most important; don't buy a poorly made counterfeit that sells cheaply (although the scammers are catching on to that) on fleabay/amazon. Get one from a dealer with a discount online store like Olathe Toyota in KS.
    Yes, but what I'm getting at is what are the numbers for" below normal" and "below operating parameter".
    Everyone is happy to bandy about general (and false) statements but very seldom are those thresholds qualified (which would then lend truth to the qualified statement).
    The qualified statement is far more useful and might see fewer ok batteries replaced needlessly.
    Danno5060 likes this.
  9. BrokenPipe
    34
    NorCal
  10. dolj
    dolj Senior Member
    8,652
    4,403
    Whether I know the answer or not is irrelevant and, again, also not the point.
    More relevant is whether the people that make the claims know. To date, it seems they don't.
  11. Danno5060
    405
    209
    Wyoming
    Got a new one (Toyota off ebay) - installed it and everything works as it should. The world is back to spinning in "well-greased grooves".
    Thanks for the help.
