Just turned on my HVAC system
Discussion in 'Fred's House of Pancakes' started by Lee Jay, Oct 25, 2022.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I suppose, but in practice, I change things a couple times a year.
  2. Trollbait
    12,822
    With programmable thermostats I can have the heat come on downstairs when I'm down there, and the heat come on upstairs when I head up to bed.
  3. Lee Jay
    5,850
    4,036
    That wouldn't work for me. First of all, I have three levels and two of them are used for sleeping (basement and second floor). Second, I change positions in the house about 50 times a day!
  4. hill
    9,027
    Same here ... yet the AC industry seem to suggest vents closed put a strain on AC systems ... even on the heating side;
    5 Issues Caused by Closed Air Vents - The AC Hero
    still - and even tho it bugs the better half, the vents in all 5 rooms of the walk out basement remained closed. It uses less energy just to maintain temps in 1,800sq feet compared to double that volume.
  5. Lee Jay
    5,850
    4,036
    I only tend to restrict flow in two-three at a time, and generally in those that have way too much flow in the first place, such as those right on the trunk duct. There's one about 6 feet from the furnace that, if open, feels like standing under an enormous hair dryer. I also cover up an additional return air duct I added in the winter and leave it open in the summer.
  6. ChapmanF
    19,010
    There's a little bit less black magic about it these days, when so many residential units use an ECM blower that can detect its own airflow (every now and then, while blowing, it cuts back the power for a moment to see how much its RPM drops, and converts that into how much air it is moving), and adjust its own speed to produce the airflow selected in the setup. If you close off some ducts, it may just speed up a little to deliver the right amount of air through the ones you left open.
    You just have to make sure the static pressure in the system never goes above the specified limit, so the blower can do its job.
    It's easy enough to build a rough-n-ready incline manometer out of some clear tubing and hose clips, I just mounted one permanently as part of the furnace installation, one static-pressure probe just downstream of the air filter and the other just upstream of the evaporator coil. So, if I ever want to see if the pressure's in spec, I just look.
  7. fuzzy1
    10,705
    ... looks like mostly scare FUD from "Josh" in North Richland Hills ...
    I'm not the least bit concerned about my heat pump system causing carbon monoxide poisoning.
    Zythryn likes this.
  8. ChapmanF
    19,010
    It could be a legit concern especially with older blowers that weren't actively speed controlled.
    I had to be careful replacing my old furnace with a higher-efficiency one, because it discharges lower-temperature air so it needs to move a higher volume. I was able to keep the old ducts, but that was after carefully checking the static pressures with the new system to see the limits weren't exceeded.
