JustDidIt - Modding My 2007....The 2008 Touring died.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Jul 9, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Haha Gardener, KS is near where i grew up.
    As long as you pick up part numbers 48811-AB010 or the newer 48811-AB011 from Toyota...or save money and snag a 2002-2008 Matrix or 2002-2010 Corolla front sway bar from a junkyard...All 24mm front sway bars that will work with the 2004-2009 USDM Prius.
    According to the ad, the part numbers match up.
  2. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    Thanks.
    I have no choice but to buy new, as the matrix was never sold here in oz.
    Jason.
  3. Jason in OZ
    271
    112
    Sydney, Australia
    thanks for the info. i just ordered the front stabilizer bar, bushes and brackets, along with the rear stabilizer bar bolts and nuts from toyotapartsonline, and all for the bargain sum of only $203 AU delivered :)
    now ill i have to do is order up the progress rear 24mm bar, and im all done.
    thanks again.
    Jason.
    Daves09prius likes this.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  5. Kishore
    Kishore Junior Member
    San Diego
    Wow --Very impressive list of mods- and am I glad you are local (y) I am a newbie with '07 touring.
    So what has been the mods/updates you have got which you think had biggest impact on MPG and drive?
    Regards,
    Kishore
  6. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I can't wait to see more pictures of your "new-to-you" '07 Prius!
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    TintWorld coming thru last night with my Gloss Black roof vinyl wrap.
    Jay, the owner did an awesome job, even stayed past 8pm to make sure it was everything was how we had discussed. Highly recommend checking out the Vinyl wrapped M5, their Stereo showroom or if your looking to have tint work done, check them out if your in SD.
  8. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    how much did you pay for the roof wrap? ive been quoted around 250-300 here in NY to get my roof on my C covered.
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    $250
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Finished my custom exhaust
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    how's it sound? how's it run?
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Improved flow overall with my custom intake. Been said by a co-worker that it sounds throaty like a VQ engine but deeper. The hybrid battery charges up faster, no MPG update yet on my 2007 but it improved quite a bit with my 2008. Definitely feels quicker,but no dyno proof of course. Really feel like the OEM headers, the (2) cats, resonator and muffler as well as the reduced piping size really limited the potential of the little 1.5L.
    Removed OEM 1NZFXE steel header
    Installed a 1NZFE DCSports Ceramic header #SHC4401 with custom welded flange
    Removed (1) OEM catalytic converter
    Removed (1) OEM resonator
    Installed (2) 4" round Magnaflow mufflers #10414 directly behind O2 sensor
    Mandrel bent 2" piping
    Custom dual loop muffler created from (2) 4" round Magnaflow mufflers #10414 and Magnaflow's exhaust tip #35168
    m.wynn, DanGiant and sfv41901 like this.
  13. Daves09prius
    680
    161
    Gettysburg, PA
    So I was watching a video last night of a BMW front Sway Bar installation, and they used poly-busings. I know you had poly-bushings installed previously but couldn't get over the squeaking noise the poly-bushings made. In the BMW video they used a product Liqui Moly LM508 Anti-Seize compound (go to 9:50) of the video:
    They coat it all over the poly-bushing to stop any squeaks.
  14. Daves09prius
    680
    161
    Gettysburg, PA
    Have you tried that compound on your polys or did you just use regular grease?Here's a link to the anti-seize compound on amazon. -- Give it a try, it might work?
    BavarianAuto, 10 Months ago:
    ...We have found that the Liqui-Moly copper anti-seize compound performs better than silicone grease, in the long run. Less wear of the urethane and less potential for squeaks.
    #234 Daves09prius, Jun 13, 2014
  15. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I got the squeaks to go away on my 2008 when i replaced the bolts to the bushing bracket and re-tightened them down to 14lbs of torque per spec. I haven't installed one on my 2007 yet because the one I had on the 2008 got damaged when I totaled it. Once I get one and install it, I'll b using the same grease that came with the previous poly bushings.
  16. Daves09prius
    680
    161
    Gettysburg, PA
    Is that really 14 lbs of torque? That's it? not tighter?
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    This is what i got from the 2004 Prius svc manual
    Step 24. INSTALL FRONT STABILIZER BRACKET NO.1 LH
    (a) Install the stabilizer bracket No.1 LH to the front suspension crossmember sub–assy with the 2 bolts.
    Torque: 19 N⋅m (194 kgf⋅cm, 14 ft⋅lbf)
    Check out the attached PDF
    #237 Justdidit, Jul 18, 2014
  18. Daves09prius
    680
    161
    Gettysburg, PA
    Wow! Cool, 14 lbs it is! :) I'll have to loosen mine up and see if that makes the squeakiness to go away.
    My poly bushings don't squeak until I drive over a pothole or speed bump. When it makes noise though it sounds awful!
    Thanks Justdidit!
  19. 69shovlhed
    2,170
    751
    Delaware
    might want to glob some more of that copper grease on em when your in there.
  20. Autoconfig
    Autoconfig Junior Member
    Bay Area
    Thanks.
    #240 Autoconfig, Aug 14, 2014
