JustDidIt - Modding My 2007....The 2008 Touring died.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Jul 9, 2012.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Made some progress...just can't rush this... nor do I need to when I have a second set of taillights.
    Still using Tamiya "Smoke" TS-71 and Krylon SuperMaxx All-in-One Satin black.
    #381 Justdidit, Jan 16, 2017
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Spent some time looking at repair manuals of the 1NZ-FXE - Terminals of ECM. Came up with this...for wiring in some sort of piggyback or standalone engine management system.
    See anything I may have missed if you compare the attached PDF?
  3. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    This is looking great! I can't wait to see how it turns out. I have been wanting to put a turbo on mine for years now, this may be the inspiration I need to actually do it.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Camcon units are hard to come by. Last one eBay was for Hondas and the older models aren't cross compatible. So.... I picked up a Greddy e-Manage Ultimate. Wiring is a quite a bit more intense...a lot more wires to connect. Hoping to find a tuner in Dallas... or I may have to drive to Houston for tuning...
    Sillywizard and RightOnTime like this.
  5. Sillywizard
    Sillywizard Junior Member
    Sweden
    The awesome in this thread is beyond belief! I love it! Not that I'll ever get close to doing anything like this, but it is fascinating to follow!
    Keep up the great work, more power to you!
    /Sillywizard
    RightOnTime likes this.
  6. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    When I worked for boostlogic, we did a lot of tuning work with PRT and Dallas performance up in the DFW area. Or theres enginelogics inc. in my neck of the woods down in the Houston area. Of course theres Boostlogic and Cobb based in Austin. If you come down to Houston let me know though, I'd love to see the ride!
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Thanks for the advice!
    PRT Performance flat out said "No!" to me and the prius. lol
    MVP Motorsports Inc also said "No!"
    Dynosaur Performance was at least able to recommend a guy, he's been busy, but i'm following up with him.
    Dallas Performance, i'll definitely check them out.
    EngineLogics looks good...I'll definitely chem them out as well.
    I have offices in Austin and Houston so if I don't have any luck in Dallas, i was planning on hitting up Meghani Motorsports in Houston and I'd definitely check out Boostlogic and or Cobb. If i'm in the area, I'll definitely hit you up.
    I'm currently trying to figure out if I can make my own custom ECM harness so I won't have to cut up my OEM wiring. Looks painstaking and tedious....
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Realized my earlier post of the first ever supercharged then Turbo NHW10 1999 Classic Gen Prius story - the PDF didn't attach, so here it is again.
    It's a good read - the trouble that Julian Edgar went thru to get the Prius up from 43kW (57hp) to 55kW (73hp)...a rough 30% increase in power.
    Shows I'm in for a world of issues...
    Summary of Turbo Modifications:
    • Turbo – GT1241 from hydrogen turbo kit
    • Fabricated exhaust manifold – Hydrogen Turbo Kit
    • Fabricated intake and intercooler plumbing – 2 inch and 1.75 inch mandrel bent – Hydrogen Turbo Kit
    • One heat range colder Iridium spark plugs – 2 step colder NGK 2667
    • Intercooler – Hydrogen Turbo Kit came with a Spearco
    • 2-inch exhaust – Car is already setup with a custom 2” Magnaflow exhaust.
    • Airflow meter – use the one I made for my custom air intake
    • Intake airbox – Will use a cone style filter, not concerned with the extra noise from not using a air box.
    Still need to buy:
    • GFB recirculating blow-off valve
    • Turbo oil lines
    • Fuel supply system – in-tank pump, external pump, two pressure regulators, solenoid, one-way valve, two control relays
    Still need to figure out:
    • Electronic switching of oxygen sensors and fuel pressure via the Simple Voltage Switch kit working off airflow meter signal - Hopefully the Greddy EMU will help with this.
    • Airflow meter electronic interceptor – Hopefully the Greddy EMU will help with this.
    • Decrease in high load boost using a solenoid-controlled bleed on BOV pressure line via Simple Voltage Switch working off airflow meter signal – Either Greddy EMU or some other Electronic boost control.
    • Engine 'on' signal provided for 30 seconds after boost event via a modified Simple Voltage Switch working on hybrid ECU 'full air con request' input – still need to figure that out.
  9. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Thats the problem I have been running into with a lot of the prius mods, definitely a car you have to MacGyver together for certain things. I haven't even seen anything in the Japanese and Russian markets for a new ECM harness.
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Couple new cell phone pics after washing the car this weekend. Didn't have time to do much of anything else...
    PutPutMobile and Acidbass32 like this.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Was wrapping up a few mods this weekend. Finished up the taillights - sanded and clear-coated.
    Then started on my headlights that I added new Morimoto XSB 3.0 LED strips and sanded and clear-coated them as well.
    Then this happened today...
    Luckily my wife and I are OK. Got sandwiched between two cars. Hopefully I can start this project again soon.
    Getting close on the turbo charge pipes too!
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  13. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    So glad to hear everyone is OK
    Justdidit likes this.
  14. Burna J
    1,071
    3,341
    53
    Long Beach, CA.
    That totally sucks....... such a beautiful ride. :( Just good to hear you guys are all right.
  15. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    At the end of the day this is a car, things happen. Man... that sucks. All the work and bam. Are you going to end up getting another 08/09 and swap the parts? Most of the work should be easier the second way around.
  16. sidecar
    sidecar Member
    342
    45
    Australia
    is it me or didnt this happen to you before?
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    2nd time... my silver 2008 was totaled in SanDiego. That's where I pulled the motor to rebuild for this 2007 and using it for mocking up the turbo and charge pipes.
  18. sidecar
    sidecar Member
    342
    45
    Australia
    gezus H man, Im so sorry
    please keep us informed of your continuing journey
  19. JC91006
    16,938
    8,647
    The car doesn't look bad, new rear bumper and hood, you'll be back on the road again
    SM-N900P ?
  20. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Ouch! Glad your alright!
    Love the ride! I'm sure you'll have it back as good as new in a jif.
