K&N filters v/s paper filters
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhedges, Mar 25, 2013.
  1. Bill Norton
    Bill Norton Senior Member
    2,154
    734
    MONW, Ks.
    WOW..o_O
    But, but.. the amount of dirt would remain the same, no?
    Where did all that dirt go?
  2. Prius7Prime
    Prius7Prime Junior Member
    58
    Long Beach
    2012 Prius Alpha
    K&N filters do flow more air it's been proven time and time again, but maintaining them to work properly can be time consuming and once you buy a few cleaning kits to keep it working properly not sure if it's worth it. I went back to using the stock filters once i found out i could buy the o.e. part on line for $16 if you decide to go that way be be sure to check out the place i get mine at you'll be happy you did all their o.e. parts are cheap. 17801-37021 - Toyota Parts Prime
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    If the shipping is more than $5.50, I'd rather buy the same thing at Amazon and get 5% credit on my Ccard.
  4. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Probably not. I've run paper filters over 100k miles with no ill effects. To whatever small extent your statement might be true, that could only be because the paper filter stops more dirt.
  5. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Here are a couple of video's that may be of interest:
