[ KB ] EV Button Installation Instructions
Discussion in 'Knowledge Base Articles Discussion' started by Danny, Mar 9, 2004.
  1. electrick
    electrick New Member
    I just picked up my salsa red package 9 '04 Prius a couple weeks ago, and am very excited to make this mod. I have a few questions and suggestions.
    Does anyone know the part number for the connector that plugs into the HV ECU (slot 14) (the one that you modify pin 27 on).
    And if you know if that connector is available... is there a female connector available also.
    If so, my suggestion is to make a very short patch cable using those 2 connectors. If this patch cable was the length of the 2 connectors plus 1 inch or so of wire, would there be room for it inside the dash?
    I have not yet taken my dash apart to look.
    Once you have the patch cable, you insert the wires for the EV switch into it and do not modify the existing wires/connectors at all. This way your entire assembly is easily removable, leaving a pristine wiring assembly if and when you decide you need to remove your EV switch.
    Comments?
    Electrick
    2004 Salsa Red, Package #9
    adopted 04/19/2004
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Electrick,
    I'm a bit confused by your idea here. In theory the pin (the one obtained from the flasher unit under the steering wheel) should be completely removeable as it is. I don't understand what your assembly would do/provide or how/why you'd need and use a female connector (which I don't think is available). Could you try to describe your general idea a bit more clearly and I think I could help you out.
  3. electrick
    Please take a look at this pic, I think this will make it more clear:
    My idea was to leave the existing wiring and connector completely untouched and make it fast to undo. Although I guess since you have to take the dash apart to get at it, its never going to be fast.
    It may be just added complexity, and after a few days of getting used to the idea of modifying my new car I wont worry about it so much.
    Thanks
    Electrick
  4. efusco
    19,891
    1,196
    Nixa, MO
    Ah, you need two entire plugs. It does seem a big complex, but should be doable. But I have no idea where you'd find those parts.
  5. efusco
    19,891
    1,196
    Nixa, MO
    For completeness sake I'm going to post the information as stated in the UK owner's manual about the EV button. For those of you doing the install you might want to print this out and add it to your owner's manual so it will be there if/when you sell your Prius.
    Please note that the indicator light mentioned is not actually displayed in the US car.
    In the "EV" drive mode, your vehicle runs like an electric vehicle,
    only using the electric motor driven via electricity which is stored
    in the hybrid vehicle battery. This mode is suitable for driving in
    residential areas in the early morning or in the middle of the night
    or in the covered parking lot because you do not have to worry about
    noise or exhaust gases.
    Press the switch to turn on the electric motor power manually.
    The indicator light in the instrument cluster comes on. Pressing the
    switch again will turn off this function and the indicator light.
    Caution! The driver should pay full attention around the vehicle
    especially when it is driven only by the electric motor (with the
    gasoline engine stopped). People in the immediate area might misjudge
    the hybrid vehicle movement based on the absence of the regular
    engine noise.
    In the following conditions, the "EV" drive mode may not be turned
    on. In this case, the message appears I the multi-information display
    and a beep sounds.
    -The hybrid system gets hot. (after the vehicle is left in hot
    weather, after driving on the slopes or high speed driving etc.)
    -The hybrid system gets cold. (After the vehicle has long been left
    below 0oC (32oF).)
    -During gasoline engine warm up
    -The hybrid vehicle battery assembly charging level is 3 or lower.
    -The vehicle speed is about 45 km/h (28 mph) or over
    -The accelerator pedal is depressed strongly or on the slopes.
    -The defroster is in use
    Turning on in cold weather
    When the engine is cold (for example early morning), it will start
    warming up about 10 seconds after the READY light comes on. During
    the warming up, the EV drive mode cannot be turned on. (The time
    before the engine starting varies depending on the temperature, air
    conditioning condition, etc.) To use the EV drive mode, press the
    switch before the engine starts.
    In the following conditions, the "EV" drive mode may be automatically
    cancelled whilst driving.In this case, a beep sounds and the "EV"
    drive mode indicator light flashes three times and then goes out.
    -The hybrid vehicle battery assembly charging level is 2 or lower.
    -The vehicle speed exceeds about 45 km/h (28 mph).
    Although the available driving range differs depending on factors
    such as the hybrid vehicle charging level or air conditioning
    condition, it usually ranges from about several hundred metres to 2
    km (about ½ mile or less) when the vehicle speed is less than about
    km/h (28 mph).
    As your vehicle is designed to have the best fuel economy during
    normal driving (driving in the combination of gasoline engine and
    electric motor power), frequent use of the "EV" drive mode may worsen
    fuel economy.
  6. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Anybody know how to do this to an '01?
  7. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Got mine partly installed. Thanks to Toyota of Japan!
    Then I got a bit worried when I hooked the battery back up and my gas gauge read empty on a full tank! I finally found the note in the owners manual about that! Gas gauge started functioning after 3 miles or so of driving!
    Anyways my button is in and it lights up but no function yet. Have more to do to get
    the darn wire across the dash board! So just that one left to do.
    Jan 8:
    Got my last wire in! Used a screwdriver on the terminal and
    then pliers to crimp. No solder. Had open connection. Squeezed harder
    with pliers and got continuity. Pliers on side so little knives would cut into
    wire. (I used 26 wire, which was a bit small for the connector.)
    Went on a test drive to warm car since I just got triple beeps due to temp
    low. After warm up everything worked great. Noticed this time the
    gas gauge did not get lost like the first time I took off the battery.
    EV button is great, esp when in parking lots! Seems like one of the
    best uses: Why warm engine on idle, or try to keep it warm when you
    are about to shut down.
  8. dgstan
    dgstan Member
    159
    OC
    I've got this mostly done. Thanks to everyone who posted their experiences - it couldn't have been done without the excellent tutorials.
    I managed to melt my pushbutton switch while soldering, so now I've got two wires sticking out of the hole, but when I short them together for a moment, EV mode kicks in and works as advertised.
    A couple of notes:
    1. I grounded to a 12MM bolt right next to all the ECU harnesses. The bolt is located directly behind where the passenger vent would be. It looks like that's a good ground - all the metal cases for the plugs connect to that whole metal area. Does anyone see a problem with this?
    2. Be very careful of sharp edges near the plug that you tap into. I sliced up the back of my hand pretty good last night.
    3. I had a hard time getting the plug back into the jack after adding the necessary pin. It just would not go in. I thought something went horribly wrong (bent pin or the newly added pin wasn't the right size). But after a bit, I realized that I hadn't pushed the pin retainer all the way flush with the plug.
    4. Cuts on the back of the hand tend to bleed profusely.
    All in all, the install went smooth (so far anyway). I'd rate it at about a 6 out of 10 for difficulty. It took about two hours what with the soldering difficulties and the bleeding.
    Thanks Again to everyone who contributed to these posts.
    DGStan
  9. SAPrius
    SAPrius New Member
    137
    San Antonio, Texas
    I donate five points to you for band-aids!
  10. efusco
    19,891
    1,196
    Nixa, MO
    Stan,
    I think that ground should be fine...obviously it's working....Congrats!
  11. dgstan
    dgstan Member
    159
    OC
    I thought you all might like to see how it turned out. I'll try to attach a picture here. I hope the picture looks OK (it's from my Moto V505).
    What you see is the EV button with a rocker switch right below it. The rocker is a DPST that controls the Phone/NAV speed sensor defeat. It all pulls out and can be disconnected easily. I purchased the smallest rocker and button I could find (that still looked decent). They barely fit into the plastic blank.
    I thought about locating the Phone/NAV switch elsewhere, perhaps somewhere a passenger could reach it, but I came to the conclusion that this location was the cheapest part of the car to modify and, in case something went wrong, restore back to factory condition.
    Installation wasn't too hard, provided you posess the mad Dremel skills. The hardest part (aside from controlling the bleeding), was tapping into the Phone/NAV wires next to the MFD. There's not a whole lot of slack in the wires for stripping/splicing.
    I even bought a new plastic blank ($5.00) that will restore the "stock" look if I ever need to reverse the changes.
    Again, I couldn't have done it without all of the groundwork laid by you guys!
    Thanks Again,
    DGStan
  12. efusco
    19,891
    1,196
    Nixa, MO
    DGStan!
    Very nice and a great concept to integrate the BT/NAV & EVb all into the OEM spot for the EVb. Well done and congratulations. I know you'll enjoy all those features.
    I have some requests.
    1)What is the part number for the 'blank'...I'd like one as a spare in case I need to pull my EV button.
    2)What are the parts numbers and where did you buy you DPST and momentary button that fit so nicely in your old blank. I suspect others will want to emulate you mod and you can probably save them a lot of time with that info.
  13. dgstan
    dgstan Member
    159
    OC
    Doctor,
    Thanks for the kind words. I think it looks pretty good, but the best part is that it all works as advertised!
    1). The P/N for the OEM blank is: 5553948010 (Cover, Spare - $5.02 list)
    2.) I purchased the parts at Action Electronics in Santa Ana, CA. Their phone number is: (800) 563-9405.
    The rocker switch is made by Philmore (LKG Industries), P/N 30-043 ($4.29). I used terminals by Noble (P/N 508M Female .187x.020 - 2 per pkg.) to connect to the switch ($.88 x2).
    The pushbutton was loose and therefore had no packaging, so I don't know the MFG or P/N. However, the receipt says "GC-35-411 pkg switch" ($2.45). It is a momentary on button.
    Action Electronics has a website (Action Electronics) so if you can't find these parts local, you might be able to order online.
    If you do end up dealing with Action and they can't identify the pushbutton, my receipt number is 268601. Maybe they could look it up that way. I hope that's not too much information.
    DGStan
  14. Sensible Bob
    Sensible Bob Junior Member
    Salem, NH
  15. dgstan
    dgstan Member
    159
    OC
    Yeah, that sure looks like the one.
    "N O" means "normally open", which is what the switch needs to be. Momentary means that it's not On/Off (like, for example, the pushbutton switch right here on the front of my computer monitor), but just a quick short when it's pushed (like your Homelink buttons).
    DGStan
  16. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    I must be cheaper and lazier than you guys. I didn't want to screw with drilling through the reinforcing blades, and I didn't want to look for an extra oem plug. So I traced my oem plug onto a yardstick, trimmed it to fit snug, drilled a 1/2" hole in it, painted it black, and finished it with polyurethane. I have my original plug to restore to factory condition, and the swith backing cost me nothing - the yardstick was a freebie from a camping show! I also soldered in a pair of connectors a couple inches off the switch so I can do a quick disconnect/reconnect if needed.
    It's not as elegant as the plastic blank, but a lot less bloody than trying to drill out those reinforcing blades. Although if the yardstick is a little too thick, you might need to sand it down a little to screw the switch's nut on.
  17. ellis11
    ellis11 New Member
    US
    All the links I am finding for EV button installation instructions go to non-existant pages. Can anyone point me to a working link. I have a 2007 Prius.
  18. efusco
    19,891
    1,196
    Nixa, MO
  19. ellis11
    ellis11 New Member
    US
    Thanks. Is the 2004 connections the same as a 2007?
  20. efusco
    19,891
    1,196
    Nixa, MO
    connections are the same...I can't recall if the OEM EV button itself changed though--I think it did and was a bit smaller.
