[ KB ] How to eliminate Reverse Beep & Seatbelt Beep
Discussion in 'Knowledge Base Articles Discussion' started by Danny, Mar 15, 2004.
  1. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(evs @ Jun 30 2006, 08:08 PM) [snapback]279484[/snapback]</div>
    Ah, damn. Maybe swear at it louder? Maybe we can find where that beeper is and *really* disable it.
    Thrilled to hear about your EV biz. I'll have to put a pointer to it from my site.
  2. evs
    evs New Member
    <div class='quotetop'>QUOTE(darelldd @ Jul 1 2006, 11:06 PM) [snapback]279926[/snapback]</div>
    thanks ;)
  3. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(evs @ Jul 2 2006, 01:08 AM) [snapback]280022[/snapback]</div>
    :) I caught this before the edit... I'm on the road and cannot edit my site from here. I'll put in on my links page eventually. But not for a few more days!
  4. bacinmass
    bacinmass Junior Member
    29
    Outside Boston, MA
    Just wanted to add this observation...
    I find the reverse beeping to be a significant distraction when backing up -- the racket is just so darned annoying. And if there is a passenger in the car, they are asking "what on earth is that racket?" which is yet another distraction.
    Bottom line, IMHO, the reverse beep is a safety hazard, not a safety feature!
    Happy Fourth to All
  5. kurtjamesma
    kurtjamesma Junior Member
    23
    Albuquerque, NM
    The link no longer works. Help.
  6. techiechick
    techiechick Junior Member
    43
    Nashville, TN
    Can someone repost this? None of the old links work...
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    This procedure works in North American Prius. It may not work in other regions. It may or may not work in other HSD vehicles.
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO - not Trip A or Trip B
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Immediately, within 6 seconds of powering on, press and hold the Trip/ODO button for 20 seconds or more. Do not release, just hold it for 20 seconds.
    6. Then WHILE STILL HOLDING ODO button, shift the "gear" selector to R, then press the Park button. Now release the Trip/ODO button.
    7. If the last step was successful, b on or b off should be displayed in the location where the Trip Odometer or Odometer is normally displayed. b on is beep on, and b off is beep off.
    8. Press the Trip/ODO button to toggle the mode to the one you want.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if b off was selected, and should be audible if b on was selected.
    The above procedure turns off the back up beep. To turn off the driver seat-belt beep, instead of shifting in step 6, latch your seat-belt. This takes some contortions since you have to do it with your left hand since your right hand is still holding the ODO button. Be prepared by pulling the seat-belt out all the way and holding the strap in your teeth so there will be no tension. To turn off the passenger seat-belt beep, at step 6 have the passenger sitting in the passenger seat latch that seat-belt buckle. Always wear your seat belt when driving on a public road.
    And if it doesn't work the first time, try again. Most people who can't get it to work fail to hold the Trip/ODO button long enough in step five. It's amazing how long 20 seconds is when all you're doing is sitting there holding the button in.
    3 people like this.
  9. arthur50428
    arthur50428 Scotty Don't
    Clear Lake, Iowa
    Re: How to eliminate Reverse Beep & Seatbelt Beep
    Bill,
    Thank you for the help! Very much appreciated! I tried the reverse and both seatbelt fixes and all 3 of them worked perfectly...
    Any other handy hints?
    Thanks again
    Arthur:D
  10. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Grassy*butts* to the folks who have kept this thread alive! Disabling the reverse tone was the first 'modification' to my Prius after bringing it home. I have to tell you, during the test drive process at the dealership, that was the one negative item that I could find right away.
    I'm glad to see that Toyota trusts us to know what gear we're in. I only have to wonder why there's no reverse tone in any other car on the market. Are they suggesting Prius drivers are absent-minded?
    Wait, what are we talking about? Oh yes. Beeping is bad. And thanks to 'ya'll.'
  11. Hayduke
    Hayduke New Member
    Tacoma, WA
    Thanks for the tips on how to eliminate the reverse beep. I actually asked the dealership to do it for me. My salesman told me one of the Prius ubersalesmen knows how to do it, but when I went to pick up the car, it wasn't done. It was the first thing I did when I got the car home.
    I didn't notice the seat belt alarm. Is that because I always put on my seatbelt before I start the car? I also noticed if I don't wear my seat belt, it beeps for a few seconds and then it stops. Are people just trying to get rid of the few seconds of beeping?
    The back alarm, however, was terrible. So glad I got rid of that!
  12. Aviator_Guy
    Aviator_Guy Junior Member
    45
    Los Angeles
    Thanks Bill... No more reverse Beeping!!!
    I wonder if that would eliminate the seat belt beeper in my FJ? I will try it out later, but it worked just fine for my 08 Prius, Thanks!! :plane:
  13. AutumnBlue
    AutumnBlue New Member
    When I click on the link for "Read Full Article" on disabling the beeper, I get a "page not found" error. Help!
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Any chance we can recover the link? I'm proud of that contribution!
  15. QuiGonJohn
    QuiGonJohn Junior Member
    79
    Davie, FL
    Bill, Thanks!!!
    I just did this on my 2009 Prius and it worked great!!!
  16. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Just did it in my 09. Someone had posted the instructions in another thread, but specified 10 seconds instead of 20. I tried the procedure using 10 seconds at least a dozen times, and it didn't work. Had to try a couple times waiting 20 seconds to get it right, but now the beep is disabled! Hooray! I'll disable the seatbelt ding next.
  17. jhev1
    jhev1 New Member
    CT
    Worked like a charm in my '09! No more back up beeping, no seatbelt beeps either. Even though I always wear mine, I figured I might as well turn it off. Thanks!
  18. QuiGonJohn
    79
    Davie, FL
    Well the seat belt beep can be very annoying. I have a friend who always wears his seat belt. But one day we went up to a shopping center, picked up a few groceries as well as some take-out. I had gotten back to the car first so I went by the last place he was going, the take-out and when he came out and got in the car, I started home. Of course, he had to get the food settled somewhere, he was putting his wallet away and then of course he would have put on his seat belt. But this was before I disabled and we had to suffer with the annoying buzzer screaming at us. This is the kind of thing disabling it is good for.
  19. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    This method does not work on the 2010, I just tried it. Any techs out there with the info on how to do it?
  20. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Both items can be turned off by the dealer, using their diagnostic scan tool. Nobody has suggested any way to do it without using the scan tool.
