Keep cell phone and Smart Entry Fob apart?
Discussion in 'Gen 2 Prius Main Forum' started by The Ericsons, Apr 28, 2005.
  1. The Ericsons
    The Ericsons New Member
    59
    Illinois
    I would like to keep both cell phone and key fob in my purse. What will happen if I do? If they are kept in separate compartments on the outside of the bag is that ok? Will something happen to the cell phone, to the fob, or to the car if they are together? Thanks.
  2. DanH
    DanH New Member
    201
    I guess there is the potential for interference, especially from the cell phone to the fob when the fob is trying to hear the Prius when you walk up to it. I have my cell phone and fob in the same pocket and so far I have had no issues with them.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    No permenant damage will occur, though interference may occur which will go away once separated.
  4. Tideland Prius
    16,445
    Some have had issues, some haven't. So far, I've had no problems with the fob and cell or easyPAY-type tags. Despite that, I may have a dead battery sooner than normal cause I assume the phone will interfere and drain the battery faster than normal. I try to keep them apart at home but they're relatively close in my pocket.
  5. Devil's Advocate
    922
    Las Vegas, Nevada
    I continually put both the FOB and my cell phone in the same pocket without any ill effects, save one, the FOB will NOT be recognized by the car if it is within a couple of inches of the phone. The phone interferes with the signal somehow.
    If you keep the FOB and the phone in the same bag seperate them by a few inches, an inside and outside pocket might not work since they are still right next to each other. Think more like one at each end lengthwise.
  6. hschuck
    hschuck Member
    385
    bay city, ca
    I held the fob and the cell phone in contact and tried various configurations and relationships. There was no apparent degradation in the performance of the fob. It is a non-issue.
  7. tag
    tag Senior Member
    2,526
    Chicago
    <div class='quotetop'>QUOTE(hschuck\";p=\"85451)</div>
    I agree, sort of.
    My Prius failed to power up when I accidentally stuck my cell phone in the same pocket as my fob. I couldn't figure out what was wrong until I took my phone out of my pocket and put it in the front cupholder. Pretty weird.
    After that experience, I also tried various configurations and relationships but out of dozens and dozens of attempts, was only able to reproduce the event once. So, a non-issue for the most part but one that does surface on rare occasions.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    if my fob is on the battery side of my phone.. then it won't work. i have to move them apart by hitting my pocket.. then i can open the door. it's very annoying. i won't put them in different pockets though.
    any ways to shield our phones?
  9. Devil's Advocate
    922
    Las Vegas, Nevada
    I can reproduce the results EVERY time my phone and FOB are in the same pocket, whether pants, suit jacket or coat. It may have something to do with my phone, I've got that giant Nokia 3650 with Bluetooth. its big but I only paid $99 bucks for it! (new, 1 year agreement t-mobile)
  10. baeckknit
    baeckknit New Member
    Does it make a difference whether or not the phone is turned on?
    baeckknit
