Keeping EV battery 40% full?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Troy Heagy, Apr 24, 2013.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    The Volt has a mode called "mountain" that keeps the battery at least 40% full at all times. Does the Prius Plugin have a mode to keep its EV-mode battery a minimum percentage?
  2. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Not as such, but you can toggle over to HV and it won't use up your remaining EV miles until you toggle back to EV.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The Prius has plenty of supplemental power from the engine so there is no need for a mountain mode. In the rare event you are in a very cold situation with a very steep and long incline you may run the HV battery down such that you are basically running on the engine alone, you still have enough power to maintain a respectable speed.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I read a little about the Volt's Mountain Mode. Putting the Plug-in into HV mode is the equivalent, except that the Horsepower of the Plug-in does not change depending upon whether it is in EV (electric-only) or HV (hybrid) mode. In HV mode, the car uses a separate set of battery cells and operates just as a normal Prius does. Also, if you put a Plug-in with a full battery into HV mode, the Prius will consume about 20% of the EV battery capacity. I'm not certain why this is, but I think it is to allow the engine to warm up with as little load as possible, in order to reduce emissions.
    Using Prius EV mode is different from using Volt's Mountain Mode. In the first place, the Volt apparently has more horsepower available in electric drive mode, while the Prius has less; at least, the top electric-only speed of a Prius is only about 62 MPH. The second difference is that Volt owners apparently use Mountain Mode in city driving, because Volt gets low mileage in City driving. The Prius, on the other hand, gets excellent mileage in City driving, as long as you drive efficiently.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    And if that fails, you have the wife get out and push. Those grids in the rear window are to keep her hands warm in the Winter.
    drash, fortytwok and F8L like this.
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    There are two batteries, one for EV and one for HV? I must have missed that in reading about the Plug-in.
    I often go in to the HV mode with a nearly fully charged EV battery. I do this going up a hill to save the EV for more efficient operation in the flat lands. Yes the ICE goes on and warms up to 130 degrees but the SOC drops only a little. The SOC range on the EV battery is 85% at full charge and 20% at lowest level. A 20% change in EV battery capacity is almost 1/3 of the total operating range, that doesn't seem right.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    PiP will hold the charge in HV mode. By default, it starts in EV mode.
    When the battery is full (85%) and you switch to HV mode, the car will continue to discharge as much as possible blending with gas engine, until it gets to comfortable (about 70%) SOC. I believe it is done to leave room for max regen and prolong battery life by avoiding high SOC duration.
    So, it can hold the charge anywhere from 23% to 70%. You will need an OBDII reader to read the actual SOC though. Car only displays EV miles estimate based on your historical data.
    CaliforniaBear likes this.
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    There is only one battery pack in the production PiP. The prototype had 4 subpacks with one dedicated for HV operation. The production version has only one and I think the software just limits the power in HV mode.
  9. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I suspect you are remembering details about the Plugin Prius prototype. The 2012 Plugin Prius uses a single common battery pack so the HV mode uses the same battery cells as the EV mode.
    I think.
  10. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    I am unaware of anyone using Volt's MM for city driving, except when they want to have heat sooner (for pre 2013).
    2013 added "Hold" mode so MM is no longer a game for getting heat from the ICE.
    I think you are confusing posts where people with pre 2013's say that for longer trips >>40miles) to use MM for the highway segment and keep some battery/EV for the city portion at the end of the trip. This has multiple benifits, as on the highway@65 MM provides me 42-50MPG because it can use the more efficient mode 4 (actual parallel-hybrond mode) while in city it uses serial hybrid mode which yields more like 35-37MPG. Also engine mode is less noticable at highway speeds than in city driving.
    F8L likes this.
  11. Troy Heagy
    Troy Heagy Member
    1,218
    ^^^ What he said. ^^^ There's no difference between the Volt's regular mode and mountain mode as far as efficiency. Both are pure EV operations. The mountain mode mainly exists because the gasoline generator doesn't provide enough power to climb Eisenhower Pass or other long, steep terrain. The Volt's topspeed drops.
    Or anal-retentive owners (like me) who don't want to drain their Lithium battery lower than 40% in order to extend life.
    F8L likes this.
  12. CaliforniaBear
    1,180
    289
    Northern California
    A quick experiment supports this. I went directly into HV mode with a full 85% SOC. In a short 5 mile trip, avoiding EV operation, the SOC ended up at 75%. I expect a few miles more would have reduced it to the "comfortable" 70%. I'm not sure why anyone would want to do this in normal operation. Use the EV capacity while you have it and do your EV capacity "saving" (like going up steep hills in HV) at the lower SOC levels.
  13. CaliforniaBear
    1,180
    289
    Northern California
    With the 150K miles or 10 year warranty I don't worry about battery life. I do drain the battery SOC down to the 20% to 25% level in order to make the most of my cheap nighttime electricity for charging..
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I live/work less than 1/2mile from the freeway so it would be nice if I could switch the HV mode early and not use up EV range.
    I start with an EV range of 10.6+ but after less than 1 mile of driving I am down to 8.6 miles of EV range or less.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Acceleration in EV mode sure use up EV range. If you switch to HV mode on a full charge, your EV miles will still be used up, until the battery gets to the comfortable SOC. Well, that's my observation.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Mine too. Even if I switch to HV Mode before leaving the garage my EV miles will be used.
  17. Troy Heagy
    Troy Heagy Member
    1,218
    10 years will fly by fast. The warranty on my insight #2 expired in 8 years, and now I'm driving with a weak battery that would cost ME to replace. I bet you'll end-up in a similar situation with your Volt, where the year is 2023 and the battery is weak, but no warranty to replace it. (IMHO it is wiser to protect the battery by not dropping below 40%, rather than use full discharge & slowly degrade it.)
  18. drinnovation
    2,027
    586
    65
    CO
    Pretty sure the CaliforniBear is a Prius driver..
    A weak battery in the hybrid may have a huge impact on milage. On the volt it will impact pure EV range.
    I expect that by 2021, when my Volt is 10 years old, my batter will be weaker, and I'll only get 30-35EV miles compared to the 40-50 i get now (a bit less less in winter), and I'll have to charge at work to make it R/T without gas.
    Warrantied Volt battery loss at 10 years/150K (in CARB states, 8 years/100K in non CARB) is < 30% , and if many cars reach that level, then they would have lots of warranty repairs so that number should be conservative. I'd expect the average to be 75-80% capacity then. And I'm taking good care of mine in a mild climate so I expect to be on the high side of the distribution.
    The Volt's low SOC where the engine kicks in, which I see only on longer trips, so maybe 20 times a year, is 21% raw SOC, which is still in the safe zone for Li-ion longevity. More important is managing the extreme temps, especially at "full" charge (which is 86%), which the volt does well with active management.
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Honda's single motor IMA is not known to baby the battery. For the manual transmission Insight, it is up to the drive to take care of the battery health by not discharging it too deep. I am not attacking your car, just discussing the points.
    Two motor full hybrids (and plugins) like Prius, PiP, C-Max, Energi and Volt can maintain the battery SOC on-demand with the dedicated generator.
  20. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That "mountain" mode was basically a way of preserving the EV marketing approach with Volt. Committing to only a single locking point didn't compromise the efforts promoted prior to rollout. GM has since changed their stance and finally offered a HOLD mode, which allows greater flexibility with EV depletion... what the plug-in Prius offered all along.
