Keeping the car on when not driving?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PlugInPriusNH, Nov 22, 2012.
  1. PlugInPriusNH
    PlugInPriusNH Junior Member
    29
    NH
    Since I cannot program addresses into the NAV system while my wife drives the car (or vice versa), I tried to just program them in while the car was parked on the driveway. However the car shuts itself off after about 2 minutes regardless of what I'm doing. I figure if I put the car into drive it would work, but I was charging at the time so the car wouldn't let me. Is there some other way to keep the car on while entering addresses into the NAV system?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    The same thing happened to me. I was pumping air while charging. The car kept shutting down to conserve energy.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, it does that when you're charging. Found out that during the summer charging at the free charge point locations sitting in my car while it was charging. I listened to Pandora on my cell tho. to pass the time:cry:
  4. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    get a speedlock override.....then you can do all those greyed out settings and address's when in motion. Even watch a slideshow on the fly
    Dan
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ahhhhh..... don't think it solves the using accessories while charging problem:whistle:
  6. bisco
    52,854
    why would the car shut off after two minutes? have you tried it while not charging?
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, works fine when not charging/plugged in
  8. bisco
    52,854
    so what's the problem?
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    sum ppl want to sit in their PIP n use da accessories, passes da time:D
  10. bisco
    52,854
    you can also do that while not charging. i think he just wanted to know if there was some way he could program in addresses.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah.....you can.....but you gotta be quick....because the car shuts off after 2 minutes or so:cry:
  12. bisco
    52,854
    you just said it works fine when not plugged in?
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup
  14. bisco
    52,854
    well, it either shuts off, or, it doesn't.
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    shuts off when plugged in, when you have nothing else to do but sit in your car, twittling your thumbs
  16. bisco
    52,854
    polishing time!
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    everyday?!?!?!?!?!?:eek:
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If you want the car to be on for longer period of time, you gotta unplug it. Can't charge it and have the car on for a long time it seems.
    lensovet likes this.
  19. bisco
    52,854
    you need a hobby p/k.:rolleyes:
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I do!.....harrrasing you!:D
