Keeps going into Traction battery protection.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kats_Pajamaz, Jun 28, 2023.
  1. Kats_Pajamaz
    Kats_Pajamaz Junior Member
    35
    ohio
    ASRDogman, Wouldn't all of those give me a code? I've had codes before for MAF and MAP sensors as well as cylinder misfires if the fuel injectors or spark plugs aren't working? Is there a scenario in which those would malfunction, but I wouldn't be getting any DTCs?
    I will have to explore techstream a bit more because if it can try to turn over the engine, I was not aware of that.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You SHOULD be getting codes, but you are not, for some reason.
    You should at the least get a code saying that the engine is not starting.
    But you're not getting that.
    Maybe your copy of techstream is not working?
    I am not sure if autozone or one of those places rent the code readers, you could phone them
    and ask them.
    But fuel and spark are easy to test for. Or at least do not cost anything.
  3. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    You should use starter fluid, not carb cleaner.
  4. alishaynoor
    alishaynoor New Member
    multan
    2020 Prius
    Check out this for more details
  5. ASRDogman
    8,070
    4,092
    You can use wd-40, it's flamable.
    You only use enough to see if the engine starts.... It won't hurt anything.
    Now is you continue to use it, a lot, that's a different story...
