KENWOOD KSC-SW1 POWERED SUBWOOFER - Crossover
Discussion in 'Gen 2 Prius Audio and Electronics' started by jkusnetz, Jun 25, 2006.
  1. jkusnetz
    jkusnetz New Member
    55
    Following the crowd here I ordered and installed the KSC-SW1. I did the install myself, wasn't too bad. I tapped into the Bazooka wiring harness I bought to use with my Mac Prius project. If you have one of these (keeps you from having to cut the original wires) be careful as the wires were misidentified on mine, it labled the front wires as back and the back as front. Also on the 2005 prius there are 2 harnesses going into the amp. The harness that has the wires going out to the speakers also have a blue wire that is labled on the bazooka wires as ignition power. I first tapped into that wire for the ignition power, but found it only put out 5 volts, not 12. The woofer won't power on with on 5 volts. I switched to the ignition wire on the other harness and that got it working.
    Anyway, what crossover setting do you guys have your subwoofer set to?
    Right now I'm not running the remote control into the cabin of the car, I just left it in the trunk hoping that I could just find a good default setting to use that would sound good with most of my music.
  2. pre-cbs
    pre-cbs New Member
    103
    <div class='quotetop'>QUOTE(jkusnetz @ Jun 25 2006, 06:56 AM) [snapback]276444[/snapback]</div>
    I have mine set around mid point
  3. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    If you listen mainly to one music source, it should be easy to find a good level and top frequency. However if you mix cds with FM radio, you will probably find that many FM stations overboost the bass octaves as transmitted. A single compromise setting may not be possible.
  4. pre-cbs
    pre-cbs New Member
    103
    <div class='quotetop'>QUOTE(tochatihu @ Jun 25 2006, 08:30 AM) [snapback]276482[/snapback]</div>
    tochatihu, do you keep your phase switch in or out?
  5. tochatihu
    9,549
    3,685
    2001 Prius
    Phase switch 'out'. Less bass boost (on mine) when it is 'in'. Just try it both ways.
  6. HYPERPRIUS888
    HYPERPRIUS888 New Member
    I ordered the KENWOOD KSC-SW1 DUAL 6.5" POWERED ENCLOSED SUBWOOFER which I plan to put under the front seats. I have NAV so I am not sure it will fit under the Drivers seat. I need detailed photos and exact wire locations and colors to pick up my signal and power for an 'O6 Prius. Thanks for any help.
