Kept Valet Warm
Discussion in 'Prius c Main Forum' started by wlee, Feb 16, 2015.
  1. wlee
    wlee Junior Member
    39
    2014 Prius c
    Went to a longer than ideal lunch today and handed my C2 to a valet. The battery meter was almost full. It was probably 5-10 degrees F. When I finished lunch, I got the keys back from the valet guy and went in my car to notice it being warmer than expected...and my battery meter down to two bars. My car was the only hybrid in the lot and that dude used it to keep himself warm for two hours!
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Damn. Thats a shame. Im sure you are not the only one that has happened to. Probably happens to everybody all the time they use valet. Bring an exotic car and they use it.
  3. KYBlue
    KYBlue Active Member
    227
    112
    Seems odd. When I remote start my C, even with the battery low it always ends up 1 bar above normal full because it must sit there and run. Now if it was hot and you came back and the battery was down sure. But at those temps the car would have kept kicking on to keep the coolant warm for the heater. Try it, your car will never get the battery that low left parked in those temps with heat on. May have been something else going on though?
  4. wlee
    wlee Junior Member
    39
    2014 Prius c
    I've kept the car in neutral w/ e-brake a few times while waiting for people and don't think the ICE kicked in. I'll try to pay more attention next time I take the car out.
    But youre right, there might have been something else going on. It was just odd and I knew I had to let it go with the valet because there's nothing I can really do about it.
  5. firstrival
    firstrival Member
    102
    The ICE will not come on in neutral. You like living dangerous.
    Fahfoofnik likes this.
  6. kingnba6
    1,018
    242
    NY
    the engine will turn on i think but not charge the battery.
  7. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Yes in HSD neutral just means no power can from or go to MG1 or MG2. So it’s impossible to charge hv-battery in neutral.
  8. wlee
    wlee Junior Member
    39
    2014 Prius c
    I've only done it in 2-5 minute intervals (habit from driving stick), but I think the parking attendant may have done this much longer in my car in order to use up almost all of the HV charge
  9. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    At cold temps like you had, the electric heaters in the C will turn all the way on (three sections). They consume a total of just over 800 watts, not including the blower motor. That will drain the HV battery to a "start ICE" level in pretty short order (like five minutes at full heat). Most likely, only the two 160 watt elements in the grid were coming on, but that will also run it down pretty quick.
    minkus and wlee like this.
