key detected in vehicle - while driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cantgoback, Oct 30, 2009.
  1. bisco
    52,883
    both fob's came in at 3.03v, so i'll probably pick up some new ones, but i doubt that is the issue.
    can't test the 12v today because i've been charging since this morning, running around and recharging. it will have to wait until tomorrow morning.
    it was raining yesterday, but if it was the 'water dripping over the door locks' problem, that's a new one on me.
    the only other thing i can think of is, just before leaving, our daughter came out to the garage to unlock the hycam, but had my key. so she unlocked an already unlocked prius.
    i forgot that another thing that happened during all the beeping and lights flashing was the doors locking themselves (or unlocking) so maybe it was a computer glitch.
    anyway, 40 miles so far today, and no issues.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Thanks for updating;).
    Probably wouldn't have to worry about you coming back to update:p.
    52,883
    if i don't show up, check the 'in memoriam' forum.:cool:
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    That won't work. You were the last one to post in May 2016. :eek: :cry:
    bisco and Raytheeagle like this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Let's just hope that Mrs. Bisco knows to update us:whistle:.
    bisco and Prodigyplace like this.
  6. bisco
    52,883
    i'll make one of those post mortem video's, with instructions.;)
    Raytheeagle and Prodigyplace like this.
  7. bisco
    52,883
    12 volt was 12.8 after the car had been off for an hour last night, and 12.6 this morning. i think i just had my first msdos prius moment.
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    Please explain... I am still a newbies and your comment "does not compute" for me.
  9. bisco
    52,883
    which part?
  10. bisco
    52,883
    strangely, after sitting another 8 hours, it is up to 12.75 (n) it may be that i didn't have a clean ground.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    "i think i just had my first msdos prius moment."
  12. bisco
    52,883
    computer glitch. or as i like to say, thank you bill gates.
  13. Prodigyplace
    12,720
    11,852
    Central Virginia
    I thought ms-dos would be 8.3 volts :D
  14. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    I've seen that occasionally, usually when I've exited with the hybrid system "ready," then returned and started driving. Its little brain is easily confused if you do anything out of the usual routine.
  15. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I got the "Key detected in vehicle" message, doors [un]locking and yellow triangle three times on my drive home this afternoon. I checked and sure enough, the rear hatch was slightly ajar, but not enough to set off that dash indicator.
  16. slalomboi
    slalomboi Junior Member
    Seattle
    I have a 2010 that had the same Warning issue; it WAS the hatch being insecure. Thanks for all your comments. Loving me some PriusChat!
  17. Willy2010
    Willy2010 New Member
    New Mexico
    My wife had a blanket spread across the back, thin enough to allow the hatch to latch, but thick enough to cause this warning.
  18. Prius2010usr
    Prius2010usr New Member
    Yes, I had the same problem. While driving “keys detected inside the car” and door open sign shows up in the dashboard.
    Solution is very simple, my trunk inside light was not off or on, it was in the middle position. I turned it on and now problem is gone. No more door open sign in the
    please share it, as this is very common thing that happens when we put the groceries. Accidentally move light switch to a crazy middle position(neither on or off)
  19. bisco
    52,883
    got the message again yesterday. i had put something in the hatch, so that was probably the issue.
    but i still don't understand why toyota programmed that message for the hatch, instead of 'hatch not closed securely' or something that would give a clue to the problem.
    i have to wonder what 'key detected in car' meant to the engineers?
  20. spoonerisms
    spoonerisms Junior Member
    Southern CA
    You win the helpful internet post award today! I had this exact message and it was also my hatchback door! I was certain I needed a new fob or something worse!
