Key Detected in Vehicle!
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by priuscatprimeguy, Feb 17, 2018.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Occasionally I get a message that the Key Fob is detected in Vehicle. Which is mysterious because I'm in the car and it's obvious that the Key Fob is detected in the Vehicle. So why the silly message? I had to take the Key Fob put of my pocket when I departed the car and closed the door and tried to lock it by placing my finger on the door handle, I had to use the lock function on the Key Fob to lock the doors. I looked inside the car and noticed that the "key is detected in vehicle" still being displayed on the MFD
    HPrimeAdvanced likes this.
  2. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Bad battery in the FOB?
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I have seen that message periodically on my Gen 4. It also makes sure the doors are unlocked when it is displayed. I just ignore it and start the car as usual.
    You cannot use SKS to lock the car with a fob inside. You need to use the mechanical key. This is documented in that batch of firestarter they call a manual. You received this when buying the car.
    padroo likes this.
  4. Mark57
    2,945
    2,736
    OK
    Rear hatch not being completely closed is also a common cause for this.
  5. bisco
    49,399
    maybe the second fob fell down between the seats.
    Andyprius1 and HPrimeAdvanced like this.
  6. Prodigyplace
    11,696
    11,318
    Central Virginia
    If the rear hatch is not completely closed, my car tells me that.
    I do not use the rear hatch often and the "Key in Car" message seems to be somewhat random.
    Andyprius1 likes this.
  7. priuscatprimeguy
    2,730
    2,640
    lol, you're all wrong:p turns out I have my Galaxy S7 Edge in the same pocket as my key fob, so when the phone is in front of the key fob in my pocket the signal from the key fob is partially blocked, happened again tonight when I got off work so I pulled my key fob out of my pocket and set it on the passenger seat, problem resolved:D
    Andyprius1, m.wynn and HPrimeAdvanced like this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Yes, Leave your fob inside the house and see if it will go into ready
    Had not seen Post 7
  9. priuscatprimeguy
    2,730
    2,640
    I know where my second key fob is, it's in my dresser drawer which is 14 flights up from the car:p
  10. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    So the 2nd fob is in the clouds.
  11. priuscatprimeguy
    2,730
    2,640
    streaming as we speak:p
  12. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    DUDE! Attach your keys (including your Prime's) to a carabiner snap hook, which you snap to a loop on your pants. Works like a charm!! As far as the cell phone, throw that distracting device away!!
    AChoiredTaste.com
    DonD, Andyprius1 and priuscatprimeguy like this.
  13. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    Where Priuscatprimeguy resides. How celestial!
    AChoiredTaste.com
    priuscatprimeguy likes this.
  14. prius4-me
    prius4-me Member
    58
    29
    Denver, Colorado
    Then you can flip the carabiner up over the top of the waist band and down the inside so it is not even exposed - if you care about that. (Which I do.)
  15. Andyprius1
    2,327
    859
    Cool CA
    Now how are we supposed to know that? See, you don’t need us"......................."..............boo hoo.
    Prodigyplace likes this.
  16. Andyprius1
    2,327
    859
    Cool CA
    The whole concept of a exposed or unexposed carabiner is frightening.
