Key Fob Case - Recommendations
Discussion in 'Prius v Accessories and Modifications' started by prevee5, Nov 3, 2013.
  1. prevee5
    prevee5 Member
    122
    Monrovia, California
    I just read that the Prius v key fob costs about $300 to replace. That being said, I'm looking for recommendations for the best key fob/ remote case or cover. Saw some pretty cool silicone ones but wanted a source for ones with a perfect fit. Any suggestions?
  2. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
  3. Kurt E Sanders
    Kurt E Sanders Junior Member
    36
    Xenia, Ohio
    2013 Prius v wagon
    Just ordered two, and blue is perfect! :)
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
  6. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    I have two of the blue ones mentioned above….
    I have a pic of it posted somewhere on Prius chat, I can add another picture here.
    I've had it for sometime time now and its holding up and like most it does not pick up lint and such when in a pocket
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'd really recommend one of those acrylic/rubber (stretchy) covers as is available at "The Jacket Store"--you can google it.
    I had one for my Honda Fit fob and loved it.
    What I like is that they cover nearly everything on the fob except the buttons...thus protecting everything. Unlike some cases that leave the whole front exposed. Also the extra thickness makes the buttons more recessed, easier to feel in the dark..and less likely to "accidentally" be pressed in a pocket. Also being acrylic/rubber...I imagine it potentially adds a degree of water resistance to the fob.
    You can get them in Black...which makes the fob essentially look unchanged. Or various other colors, even Camouflage if you so desire.
    Having said all that? I've yet to order one for my Prius....got to do that....
  8. Sandtiger
    Sandtiger New Member
    South Carolina USA
    2014 Prius v wagon
    I too have the Amazon case referenced above in the lime green (for visibility). Solid construction (the silicon rubber ones I saw at my dealer were flimsy, by comparison and the colors were not as rich). Also note the Prius logo is on the back and ribbed frame on the front. I feel its a good investment for under a ten spot. My only knock is the limited color selection that is unrelated to Toyota exterior color choices (if you wanted them to match).
