Key Fob doesn't unlock/lock...Brand new programmed to car lock/unlock completely inop
Discussion in 'Gen 2 Prius Main Forum' started by MilkyWay, Apr 29, 2019.
  1. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Power lock buttons work on the car itself.
    They do not work on the key fob.
    I had a locksmith program a brand new fob to car and still at square one. It's a professional store and I haven't paid them yet --- they are looking into why locks on the fob don't work.
    I've done my research on PriusChat and there are many posts about this exact issue. Unfortunately all the threads I've read just randomly stop! Nobody updates the solution.
    So thought I'd ask fresh.
    Also the SKS proximity function doesn't work. Car will only start with key in slot.
    FYI it is not the key fob, it is not the key fob battery, it is not the "key button" not pushed in/out, and it is not the 12V battery. And it is not the power lock button itself on the car.
    Something is going on....Many threads on it but they all end abruptly with no "I fixed it and this is what it was..."
    Figured if someone experienced this before I can relay message to locksmith but right now looking like I'll owe them $250 and it is going to be a completely separate issue.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    What year is your Prius?
    Did you try to program a brand new key? (Or virginized. Or previously used?) I see you said brand new, but want to be sure.
    Where was they key purchased from?
    Does the new key have a silver logo?
    I have more questions, but let's start there for now.
    #2 ericbecky, Apr 29, 2019
  3. MilkyWay
    823
    359
    23
    MI
    08 brand new locksmith bought.
    Vehicle was just purchased and I noticed lock buttons on fob dont work so took to locksmith. I have not seen the replacement fob yet
  4. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    So you only have one key fob for the new-to-you car.
    This fob has never worked to remotely lock/unlock the doors. Correct?
  5. MilkyWay
    823
    359
    23
    MI
    Bought car with a functioning key that starts car with key in slot. It does nothing when pressing lock/unlock.
    Now have a fresh new 2nd replacement key. Does same thing as 1st key
  6. MilkyWay
    823
    359
    23
    MI
    I'm thinking I need this. Funny, way cheaper than getting new key cut
  7. MilkyWay
    823
    359
    23
    MI
    @ericbecky can you confirm this would work and solve everything? Locks, proximity entry, proximity start, etc....? Thanks!
    eBay seller has 44 sets in stock and ad says:
    For sale is a good used smart key system set that will fit 2004-2009 Prius- we have black and silver logo systems, please specify which one you need.
    Please speacify if you have the smart key system (Silver logo)
    *** NO PROGRAMMING WILL BE NEEDED FOR KEY when all computers replaced for the key sytem***
    Theoretically only HV control module, engine ecu, smart key module, key, and immobilizer will have to be replaced- all the extra modules are thrown in for free and not necessary!
    Removed from working Prius- 90 day warranty provided
  8. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    I would think the locksmith would know how to program the keys via a reseed procedure.
    Takes about 30 minutes.
    And to reiterate some of what you confirmed above:
    Key button needs to be pressed out. (Not pressed in.)
    Tested good batteries in each fob.
    12v in good health
    If the first fob had already been correctly programmed to the car so you could use SKS and unlock functions when you got it, then you could have programmed the New key fob yourself with the chicken dance.
    The big issue here sounds like the first fob was never programmed to use the SKS function.
    If the locksmith did not know that at the time of trying to program the second fob, that could cause problems.
    kenoarto likes this.
  9. MilkyWay
    823
    359
    23
    MI
    Yes whether key button pressed in or out it will never start the car via proximity. That issue is not important to me.
    Being able to lock/unlock the car is the only thing I care about.
  10. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    Key proximity and lock/unlock are part of the same programming process.
    First go through process of programming so that fob can start the car.
    You can stop there, and some folks do.
    Second you go through the process of being able to use the key remotely.
    While waiting to get the key programming correct do you have a physical key to lock the doors. Using the one that slides out from the fob. For now you could get a duplicate made of it using a normal key key head and pit that on your keyring.
    We don't know for sure what process the locksmith is using so that is kind of the wild card. Has this locksmith programmed Prius keys in this situation before?
    Your situation is kind not necessarily typical.
    So explaining the aitisitua to him ahead of time would have been important.
    You never had a full functioning key when he was going to try to program a new one. Hopefully he realized that.
    Usually people have at least one full functioning key.
    So it is easier for the locksmith to copy from there if he uses a brand new key.
  11. stu4084
    stu4084 New Member
    Russellville, AR
    What did you end up doing? I'm in the same situation.
  12. James Analytic
    335
    52
    Michigan
    Just wanting to confirm the four ECU or modules (later in parenthesis are per manual designations) are required or if only the three next noted are required; since I've been reading that only the HV Control Module (Hybrid Vehicle Control ECU), Smart Key (Certification ECU) Module and Immobilizer (Transponder Key ECU) Module are required to be replaced?
    Guessing I can grab and Engine ECU say if happen to have the situation where one gets fried from a vehicle cat being stolen and shorting something out vs opening up and repairing the Engine ECU part.
    Even so, unless or even if is a half off sale, I'd rather save the $20 to $40 and not get the Engine ECU if not required.
    I'm asking, since we grabbed a key fob that had the cut key and the associated door lock. Actually we got two vehicles, though was able to mate up the one with our latest project where come to find out the seller had a locksmith pair the missing key fob with his Prius he was keeping. So was able to chicken dance the non-touring invested in to one set.
    Thinking for the next Prius rescue that doesn't come with a key fob and one is not available to mate, might be useful to have a whole drop in parts set. The drop in set being the key fob with key, key door lock and related minimally required ECU's.
  13. RatherBeMTBing
    RatherBeMTBing New Member
    I just bought a 2007 base without SKS. It came with one key fob, which does not work to remotely unlock the doors (it doesn't look OEM, the key in it is uncut). The fob does work in the ignition slot to start the car, but I have to use a standalone key blade to unlock the driver door from the outside. Is there a process to get my key fob to remotely lock/unlock. If I go get a second key, I'd like to at least program that one to remotely lock/unlock.
