Key Fob Extra Funtionality
Discussion in 'Gen 4 Prius Technical Discussion' started by Jorlan, Jun 27, 2016.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    works like a charm. No muss no fuss.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Yes, I have been corrected!! Thanks Kevin.
    Now I gotta try it! Alter I run 10 miles, (yeah, right!!) it will be nice to come back to a nice ice-cold Slurpy! :ROFLMAO:
    alanclarkeau likes this.
  3. Coast Cruiser
    2,267
    2,571
    No Edit button. That is supposed to say "after" I run...
    I wish our Prii had a normal, full-sized key, to go along with the Fob/Smart Key/Remote. Why? Heck, I don't know! Back to my cave..... (I'm delirious from my 73 mpg this morning! :ROFLMAO::eek:)
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I can't vouch for it working - but I read a story on PriusChat somewhere of someone who forgot to POWER-OFF when they parked at the airport for 2 weeks - and it was still running 2 weeks later - presumably not with cold air running all the time? I think they just said they locked it as normal by touching the door sensor and walked away with the "fob" in their pocket. Some other posts by people who "camped" in their Prius, but presumably they were inside with a "fob".
    [EDIT] I also am not sure if it was Gen 1, 2, 3 or 4.
    [yes, I'm not that keen on the word FOB, reminds me of "being cheated out of something", or of politician's antics.]
    #24 alanclarkeau, Jul 8, 2016
  5. Willco Electronics
    Willco Electronics Junior Member
    51
    Looking at the radio spectrum, the P4 Key Fob's radio signal alternates between 312.1MHz and 314.35MHz.
    And then there's this problem;
    Officials Unlock Mystery of the Keyless Entry System Outages - Tinley Park IL Patch
    PriUncut likes this.
  6. Willco Electronics
    51
    When I owned a 2012 P2, parked at a hotel, this happened. At night when I approached my Prius, the key fob was in my pocket, the dome light came on. My 2016 P4 is too new to tell if the same feature is available. Did anyone have the same Gen 4 experience?
  7. alanclarkeau
    7,045
    7,592
    Yes, the interior light comes on briefly when I walk past the car in the carport to go for a walk at dusk.
    RCO likes this.
  8. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Seems like it would be pretty easy for your dog to bump the gear lever into D while the car is running. All it would take is an errant tail wag, I'd hate to see your car on the news.
  9. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Only if the dog was also standing on the brake pedal.
  10. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    good point
  11. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    I doubt a dog tail could cause both a left move followed by a down move, against the springs... you might have a better chance at winning the lotto.
  12. grape808
    grape808 Active Member
    150
    153
    Hawaii
    If the fob is in battery save mode would I be able to lock the fob in the car using the manual key without the car unlocking by itself? Anyone do this? I'd like to not have to worry about getting the fob wet when I'm at the beach.
  13. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Sounds like it'd work to me. Why ask when you can test it yourself? Also, the key won't be in battery save mode if it's within range of the car.
  14. grape808
    150
    153
    Hawaii
    I'll test it but would be nice to know if others have done it. I also don't want to walk away and then find it unlocks on its own later. I'll test it next time I'm washing my car and will be around for a while.
    Good to know you have to be out of range to go into battery save mode. I just read that section in the manual today but it's a lot of info to remember.
  15. alanclarkeau
    7,045
    7,592
    It might need the battery isolated or removed altogether. But probably better than losing it in the sand on the beach?
  16. grape808
    150
    153
    Hawaii
    My original idea was to take out the battery but I don't know how the fob would hold up to many repeated opening and closing. For occasional use that would seem like the safest bet, but it needs to be something I can do regularly. Haven't had to worry about it so far since the weather's been bad but I am due for a beach day.
  17. alanclarkeau
    7,045
    7,592
    'twould work fine for me - my "regular" beach days are at least 5 years apart.
    I prefer to restrict my water usage to coffee and a shower/bath.
    RCO and grape808 like this.
  18. Redpoint5
    1,026
    509
    Portland, OR
    I've been putting my fob in a ziplock bag when I'm doing water sports. It can probably stand up to fresh water fine too, but salt water would probably kill it.
    RCO, grape808 and alanclarkeau like this.
  19. grape808
    150
    153
    Hawaii
    I tried this while washing my car this weekend. Approached car with fob on battery save mode. Door didn't open after multiple attempts. Used mechanical key to unlock, placed the fob on the dash, and crawled through the back to open the back hatch with a screwdriver. By the way that emergency latch is strange--I never felt what I was supposed to be moving with the screwdriver and the manual picture doesn't clearly show the inside mechanism, but the hatch eventually just opened.
    I washed my car and at some point I noticed something (I forget what) that made me think the fob must have switched on. Sure enough I pressed the Power button and the car started. So putting the fob in battery save and then leaving it in the car by using the mechanical key doesn't seem to be a safe option.
    RCO and alanclarkeau like this.
  20. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Do any of these hacks work on a G3?
