Key Fob Help
Discussion in 'Gen 2 Prius Main Forum' started by Chris Hill, Nov 7, 2018.
Tags:
  1. Chris Hill
    Chris Hill New Member
    Indiana
    Well two days ago I had two working Key Fobs, both SKS, now I have one working one. One was a bit beat up and I decided to change the case (cheap amazon one) out purely for the cosmetic improvement. Initially I switched the board over and put a new battery in, I tried to get it to work and it would not work, the red light blinked once when I pushed any of the buttons, but nothing worked. I then discovered that I forgot the chip, so I immediately put the chip in my new case, but it still does not work. I do still have one working key fob. Do I / can I reprogram the "new" key with the chicken dance method? Any other ideas?
    Thank You!
    Chris Hill
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Did you try a new battery in the fob?
    Will it start the car if You put the fob in the key slot?
    49,720
    try putting it back in the old case
    Skibob likes this.
  4. Chris Hill
    Indiana
    I did put in a new battery, it didn't work with either a new one or old one (battery). I will try to put it in the port and see if it works. I leant out my car for the weekend, will try early next week. Thank You for your help.
  5. Chris Hill
    Indiana
    Sorry for the delay in getting back to you. I installed the key into the magic slot and the car started fine. It has a new battery and the red indicator light illuminates when I push any button on the fob. Any ideas? Time for the chicken dance?
