key fob not detected
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Aug 19, 2020.
  1. misterdean
    misterdean Member
    206
    29
    FL
    battery has been replaced. it does open and unlock when i press the buttons. any suggestions?
  2. cthindi
    cthindi Member
    177
    85
    Connecticut
    Did you check the pushbutton below the dash to disable smartkey?
    52,862
  4. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    That only disables the proximity (SKS) system. Remote lock/unlock would still work regardless of the Key button.
    Which battery? If it is the fob battery, did you place it the correct way up? The correct way is engraved on the inside of the fob along with the correct battery model number.
