Key fob not recognized after battery change
Discussion in 'Gen 3 Prius Main Forum' started by LWeaver, May 8, 2022.
Tags:
  1. LWeaver
    LWeaver New Member
    Virgina
    I changed the battery on my 2005 prius base model.. red light comes on and it will lock the doors…. The car will not recognize the key even in the key slot. I tried the on,off twice and open door twice method but the car still says key is not present…. Am i missing something?
    51,155
    did you lose the rfid chip?
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Which battery did you change? The one in your Key Fob? Maybe you installed a bad battery? Try a different one...
  4. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Placing the key in the key slot is supposed to work even if the key fob battery is dead.
    I don't even think it is required to be in the slot, just right next to it.
    So you must have a bad fob or the wrong fob
    Mike
  5. bisco
    51,155
    it does require the chip though
  6. LWeaver
    LWeaver New Member
    Virgina
    The little rf chip fell out…. Thanks for the help!
  7. Johnny Cakes
    Johnny Cakes Senior Member
    1,042
    775
    Virginia, USA
    Key slot? I must be missing something.
  8. 3PriusMike
    3,092
    2,413
    Silicon Valley
    gen 2 prius (2004-2008) there is a slot where you can put the key fob near the start button
    Mike
  9. Johnny Cakes
    1,042
    775
    Virginia, USA
    Thanks Mike -- OP posted in the wrong forum.
