Key Fob Questions (Yes, I've read the other posts)
Discussion in 'Gen 2 Prius Main Forum' started by Seth Church, Apr 14, 2020.
Tags:
  1. Seth Church
    Seth Church New Member
    Durham, NC
    Hi everyone,
    I have a new (new to me) 2006 prius and it came with one keyfob. I put a new battery in because the fob stopped working a few days after having it and now the fob does nothing. No lock/unlock, no keyless entry, and no remoteless start. I am wondering two things
    1) can i fix this? I have seen how to connect fobs if you have an old one, but I only have this one.
    2) If i can't fix this, is there a way to connect a generic lock/unlock remote to my prius just to do the doors? I don't mind putting the key in the ignition but having to pull the tiny metal key out to unlock the doors is pretty annoying.
    Thank you!
  2. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Have you tried inserting the fob into slot in dash?
    If so, does the car start (after inserting fob into slot)?
  3. cthindi
    cthindi Member
    177
    85
    Connecticut
    Assuming the key fob starts the car as mentioned by @ydpplqbd , you could get a standard Axxess key copy milled at home depot, #35 in case of my 2005, and attach it to key fob with a ring. You can then use physical key to lock unlock and insert fob in slot to operate the car.
    Axxess+ #35 Toyota Universal Key Blank-88027 - The Home Depot
    You may want to confirm the key section matches. I have done it three times.
    You may want to check the battery again though, if it is a good battery and installed correctly. I have had bad experience with some cheap chianese batteries bought on Ebay and Amazon.
  4. Seth Church
    Durham, NC
    Hey guys- sorry i need to clarify. yes i can start the car with the fob inserted and can also unlock the car with the metal key. Im wondering if i can get a generic fob that will allow me to remotely unlock/lock the door?
  5. bisco
    51,682
    is the battery right side up?
  6. Seth Church
    Durham, NC
    Yup, the red light lights up when i push the button on the remote. Only thing i can think of is that something went wrong with the computer in the car. May take it over to the dealership but that means $$$
  7. bisco
    51,682
    seems odd that it quit a few days after buying. i don't think generic fob will work, and a new fob may not work unless you have a working fob. but i'm not positive, gen 2 and 3 are different
  8. dolj
    dolj Senior Member
    8,385
    4,271
    Wellington, New Zealand
    It sounds like you will need a reset, reseed, and add the key back to the car. You might as well buy a spare from an online Toyota dealer (just make sure it has the correct logo color on the back – silver for SKS; black for non-SKS). It should set you back $110-$150 for the genuine OEM. If you give that to the dealer, they can add it at the same time.
    ydpplqbd likes this.
  9. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Have you already checked the 'Key' button under the steering wheel?
    Raytheeagle and dolj like this.
  10. dolj
    dolj Senior Member
    8,385
    4,271
    I didn't mention this, because he said there was no [remote] lock/unlock (which should still work with SKS disabled), and he also commented that the red light illuminated when any buttons were pressed – eliminates stuck button(s).
    But, it wouldn't hurt to check.
