Key Fob Remote question
Discussion in 'Gen 2 Prius Main Forum' started by donzoh1, Nov 9, 2020.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    My 2007 is non-smart and I currently have a non-smart fob that works to start the car but not to unlock or lock doors. I don't know much about this car's history or whether this is an original fob but tech stream says it has five programmed remotes which I think is the maximum. Is this likely a problem to be fixed by simply changing the fob shell/buttons or is there something wrong with the fob internally? I did change the battery which didn't improve things.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The non-SKS fob uses an rfid chip in the case cover, so be very careful if you swap cases. Make sure to remove the rfid chip from the old cover and install it I the new one, or you'll be in serious trouble. When the fob is inserted into the slot, the car recognizes the rfid chip and allows the startup sequence. If it doesn't recognize a 'paired' rfid, start up is a no-go. So that's the good news. If the car starts, then the fob you have is one of the 5 showing in techstream. The system is almost bullet-proof.
    If none of the buttons on the fob are causing the appropriate function to occur on the car, then there is either a failure of the fob (or someone put the working rfid chip into a different fob, whose transmission is not being recognized by the car) or a failure of the receiver system in the car. When you press a button on the fob, does the small red led in the corner light up? If you hold the fob in your hand with the 'lock' icon at the top and the 'alarm' icon at the bottom, the red led is just to the right of the 'lock' icon. It blends in perfectly with the black case and is almost invisible until it lights. If it flashes when you press a button, then it's typically a good assumption that the fob is working. Many auto parts stores have displays that will allow free testing of fobs to verify they are actually transmitting.
    SFO and donzoh1 like this.
  3. donzoh1
    450
    153
    Lenexa, KS
    The red led light comes on whenever a button is pressed on the fob. I did go to Oreilly Auto and they had a fob tester that showed no transmission when the red led light was activated. The RFID works in the fob so I believe at one time, the fob probably worked properly to lock or unlock doors. At this point, can the fob be made to work properly by getting just a new case or is there likely a problem in the internal fob circuit board so that the whole fob must be replaced?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    If you believe the test results from the tool at oreilly's then the circuit board (key fob transmitter) is bad. If you don't believe it then the fob transmitter MIGHT not be programmed to the car.
    Whatever you do I would suggest that you do whatever it takes to get a second key properly programmed. It can get expensive and time consuming to try and deal with an "all keys lost" situation.
  5. donzoh1
    450
    153
    Lenexa, KS
    I tend to believe the tester at Oreillys. The clerk tried his fob and the tester reacted to it so unless the prius fob is in an unusual frequency range, my fob is not transmitting at all. Now, my question is whether the fob could be improperly programmed if the rfid chip in the same fob works to start the car. My guess would be that it's an all or nothing thing with programming so that when the fob is properly programmed, it works both for start and door unlock, assuming the transmitter is working. Either way, I'm going to get a new fob programmed so that I have an extra one.
  6. lexidium
    lexidium Active Member
    303
    143
    manchester
    I thought you could remove all previous programmed keys in techstream . . . .
  7. datsunrobbie
    datsunrobbie Junior Member
    West Haven, CT
    Check out this thread How to Program a New Key Fob for Full SKS Functionality | Page 33 | PriusChat
    When I bought my 2008 Prius it already had 5 keys programmed. I had two fobs. One worked properly, the other would only open the doors. I got a new fob from a dealer and was able to clear the other fobs and program the new one using the instructions in the thread above. It also worked for programming a fob from a third-party, so I now have 3 that are working, and did not have to use tech stream to get it done.
    donzoh1 likes this.
  8. donzoh1
    450
    153
    Lenexa, KS
    i think that’s true but the fob i currently have works to start the car so i don’t really want to remove it. i don’t know how to tell which one it might be in the list.
  9. lexidium
    303
    143
    manchester
    When my old prius was in an accident, I kept the key.
    I got another prius same year and specs and after a while the key stopped opening the door but would start the car.
    I programmed my old key in techstream so that it did both. Then I programmed the one that had stopped working so now I have two.
    Try and get a second hand key from same model, same year. I don't think different years would work. Who knows - you might be lucky.
    donzoh1 likes this.
  10. donzoh1
    450
    153
    Lenexa, KS
    So you’re thinking it would need to be same year, not just same generation?
  11. donzoh1
    450
    153
    Lenexa, KS
    One thing i’ve heard is that used fobs can’t be programmed to another prius unless they’re re-virginized. do not know how that would be done.
  12. lexidium
    303
    143
    manchester
    I definitely did it by following the youtube vid:
    2nd gen Prius both the same year, T spirit.
  13. donzoh1
    450
    153
    Lenexa, KS
    Does anyone know whether the chicken dance will work to program a new remote if there are already 5 programmed in the car? Also, the fob I have now only works to start the car but not to lock or unlock. It will not transmit. Does this mean the chicken dance won't work for programming those functions?
    #13 donzoh1, Nov 19, 2020
  14. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    No, it won't, you will have to do a different 'Chicken Dance' to clear all keys except this one (being the key that is in the slot).
    You can then do the first part of the regular 'Chicken Dance' to program the new key to start the car, but as your current only key does not lock/unlock the car, you will not be able to program those functions.
    To get both keys fully functional you will need the services of a competent auto locksmith or a competent dealer.
  15. donzoh1
    450
    153
    Lenexa, KS
    Thanks for that info. Would Techstream be usable to program the new key? If so, is there a way to tell which of the five existing programmed keys in Techstream corresponds to the old key so I don't accidentally delete that one?
  16. donzoh1
    450
    153
    Lenexa, KS
    Final success! I was able to use Techstream 12.20.024 to program the immobilizer chip and the door unlock remote functions. Curiously, the chip is programmed in the Immobilizer tab and the fob remote functions are programmed in the Body section. I ran into a snag at one point and then figured out that while the car was on, the Ignition was not on. I was quite happy that this all worked as the only fob that came with the car could start the car but not lock or unlock doors. I initially tried the chicken dance but was not successful with that so I don't know whether I had completed the correct steps correctly.
  17. dolj
    dolj Senior Member
    8,633
    4,387
    If you do not have a fully functioning remote you cannot use the 'Chicken Dance' That sequence is for adding another (brand new) key fob when you have at least one other existing fully functional key fob.
    Did you delete all the other registered key fobs?
    Do you care to share the steps that you did to make your existing key operate the lock/unlock functions?
  18. donzoh1
    450
    153
    Lenexa, KS
    In Techstream, it said I had 0 programmed fobs. After I finished the programming, it said I had 1 programmed fob. So, I'm guessing the prior owner had any registered fobs deleted? I did not personally delete any fobs. The fob that came with the car still does not operate the door lock or panic alarm although I did replace the battery and the red light flashes on the fob. It also failed the transmit test at the auto parts store. My new fob from Amazon doesn't have a Toyota Logo so who knows how long it will last.
