Key Fob Shock
Discussion in 'Gen 3 Prius Main Forum' started by wookie, Jun 15, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    considering all the improvements the 2010 has over the classics, an improvement in the security system really seems to be a no-brainer. resting on the classics "unstealable" laurels can only last so long. crooks are not stupid. they will figure out a way to steal a Pri.
    now all i have to worry about is the SPM since the 2010 just puts the crooks a few years behind the curve
    PS...
    **disclaimer**
    the post above in no way whatsover under any circumstances or in any stretch of the imagination implies that the classics are easy to steal
    **end of disclaimer**
  2. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    The laser cut mechanical key should slow down the crooks a bit. The mechanical lock can still be picked, but it requires different equipment than with the old style key. They could still use a $60 bump key, instead of a $2 one. And they'll probably have to convince a locksmith to cut it for them, which isn't going to happen.
  3. accordingly
    accordingly Member
    268
    63
    Madison, WI
    My dealer offered me a 5-year key fob replacement warranty for $200... probably worth $40 a year it if you are absentminded at all.
