Key FOB unlocking but not locking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ispoti, Oct 1, 2012.
  1. ispoti
    ispoti New Member
    I have 4 differnt FOBs and i get the same response from all of them. they will unlock the doors and the lights flash on the car and remote but when i try and lock with remote, the light on the remote flashes but i get nothing from the car.
    Please help!
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  3. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Are all the doors closed?
    Does the "door open light" come on on the dash with a door open and go off when all the doors are closed?
    Do the doors still not lock?
  4. jerrycee11
    jerrycee11 Junior Member
    PA
    Is it possible you need to change the battery in the FOB?
  5. Patrick Wong
    18,210
    6,517
    Can you lock the doors using the lock switch on the driver's door?
  6. Craigster
    Craigster New Member
    San Diego, California
    I had the same problem. I got in the car, put the fob in the slot and turned the car on. Sat for a minute or two then turned it off pulled my fob out and when I got out and pressed the lock button it was working again. Good luck.
  7. JC91006
    16,923
    8,634
    If you have 4 fobs and if any of the 4 fobs are inside the car while you are trying to lock it.....it won't lock! BTW, why do you have 4 fobs? The car only comes with 2 and replacement fobs are quite expensive.
    dorunron likes this.
  8. priuschatter2
    priuschatter2 Junior Member
    Did anyone ever find a solution to this problem?
  9. JC91006
    16,923
    8,634
    what problem are you having?
  10. Philjj
    Philjj Junior Member
    Nambour, QLD. Australia.
    ----Australia----
    So, a couple of things, the fob (any fob for the range) has a set unique code, the car reads the code, up to 5 of I think. To code look up "chicken dance Prius 08 or such" (it will become obvious as you go). I had to do it a few times to get both lock and unlock working, but no trouble since. I came here looking for no flash on lock/unlock and it turns out the hazard light switch had not quite returned back, pressed it and problem solved.
  11. Philjj
    ----Australia----
    This would be annoying for me as I keep a spare electronic key hidden inside my 08 Prius and a thin hard key in my wallet so I can always get in even if I had to break a window, if I lost my pants (not likely) with both of those in them.
