key fob
Discussion in 'Gen 3 Prius Main Forum' started by Kimberly Gibson, Oct 24, 2020.
  1. Kimberly Gibson
    Kimberly Gibson New Member
    illinois
    battery was changed in key fob. Will not unlock with buttons or with automatic door sensor; must use key. Once in the car we must place the key fob on power button to start, being in the car for a few minutes the dash reports that the key is not detected. Please help.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    First, make sure the battery is installed right-side-up. The red LED should light when you press buttons.
  3. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    My 2015 started doing that key not detected when the 12v battery was going bad. Have the 12v battery checked.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Is it not true that the "engine starting" function does not depend on the battery in the FOB ?
    And that is a different function from what the buttons do ??
