Key Not Detected, assuming short
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amtx, May 4, 2026.
  1. amtx
    amtx New Member
    texas
    2010 w/ 117k miles. Light comes on while car is running, not moving, in D or P, and a door closes from someone getting in/out. Have checked to ensure gate fully closed, replaced FOB battery. The 12V adapter in cig outlet is unchanged/unmoved for cell charging with same phone, only a cord was replaced. Assuming there is a short or loose wire because it happens with door closing. 12V battery is about a year old and no other electrical issues. Keys stay on flat part of accessory/storage area while driving.
    Is there any way to narrow this down to FOB vs car better before hitting the dealership?
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    Car ever been in a wreck or damaged there are antenna . That detect fobs. Fob's can go bad. You could have a locksmith scan you're immo system . Some of these newer scanners will pinpoint breaks antenna issues etc . Might be cheaper than the dealer you're going to drive it to the locksmith so no service call he just walks out his backdoor with the scanner
    amtx likes this.
    52,857
    maybe the door switch
    amtx likes this.
  4. amtx
    amtx New Member
    texas
    Thanks! Will look into this.
    Def no major damage. I'm the 2nd owner - I did check the carfax at dealer. Might have been minor accident + repairs....
  5. Tombukt2
    13,863
    2,519
    Durham NC
    Then I would try the passenger front door it has sensor too. I know both my front doors will unlock when I extend my hand to handle on all my SKS cars .
  6. Tombukt2
    13,863
    2,519
    Durham NC
    Passenger door?
  7. amtx
    amtx New Member
    texas
    It happens with front and rear doors after it starts. I wasn't clear on the initial description.
    Today it was fine at first and then started doing it again. Maybe the FOB was sitting slightly closer at first. Planning to go to a locksmith tomorrow to see if they can help troubleshoot.
  8. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    Lol mine does this and did it today.
    I would say its a low battery in the FOB.
    If you just changed it, it can be a cheap no name brand and is losing its power quick.
    Non issue and you can keep driving.
  9. Mendel Leisk
    42,349
    What light?
  10. AzusaPrius
    2,257
    945
    Key Not Detected message "light"
    amtx and Mendel Leisk like this.
  11. amtx
    amtx New Member
    texas
    Additional info after I stopped by locksmith...FOB battery voltage is good. The key not detected did not come on while I was there. He checked the FOB for what they typically can and said it is fine.
    The only thought he had was that the physical location of the FOB might be making a difference:
    Further forward on the flat area next to accessory panel, the signal may be getting blocked by the center line arm just enough to trigger the light/alarm.
    For now, I am trying to relocate the FOB and see how that goes. Today, it seems to have worked by moving the FOB to the rear of the flat area.
  12. Tombukt2
    13,863
    2,519
    Durham NC
    This is a gen 3 so not sure the area have you modded inside of car some way .living in etc. in our persona the key had to be in the vehicle frontal area to start car . Getting in was never an issue. without manual key . idea is it stays in pocket all time or purse. You not sposed to ever have to see it the fob.this way is never lost .hello . only mom will loose in her purse
  13. amtx
    amtx New Member
    texas
    No mods. What i mean is the flat deck under the console with the gear shift - that is where I keep the keys (stock photo).
  14. Tombukt2
    13,863
    2,519
    Durham NC
    Yeah mine never had a problem there at all I used to. Lay it they're be side of no slot doh! The idea is that the key was never supposed to come out of your pocket so it could never get lost only go through the wash.
    amtx likes this.
