"Key not Detected" with single FOB
Discussion in 'Gen 3 Prius Technical Discussion' started by SUPERCOOLMAN, Oct 23, 2011.
  1. SUPERCOOLMAN
    SUPERCOOLMAN Junior Member
    92
    Santa Clara
    After last maintenance at dealer where I got my Prius. I get two or three times of "Key not Detected" message per week when I try to start the car. I have to push start button several times for the car to detect key and start up properly. However, I don't have issue to unlock door by placing hand on the sensor and enter driver's seat. Any suggestion as to where to start? I thought it was battery issue, but that wouldn't explain why I don't have any issue unlocking the driver door by placing hand on the sensor, which I always do before I push the start button.
  2. priusguy469
    priusguy469 Junior Member
    tampa
    I have also posted a similar thread regarding this issue. Please refer to my thread when one other poster has responded. We are still looking for resolution/explaination.
    two different key fobs in one prius
  3. SUPERCOOLMAN
    92
    Santa Clara
    if you notice the title "single FOB" in my case as oppose to "double FOB" in your case?
  4. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    I'd replace the battery in the keyfob just because it's the simplest thing to try. If it's weak, the range could be reduced, leading to it working sometimes and not others. It's a CR1632 in the Gen3 keyfob.
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    A cellphone in the same pocket as the FOB can interfere with the system as can local transmitters.
    You can check the FOB battery voltage but you have to remove it to do so. Should be 3V or higher.
