Key not detedted?
Discussion in 'Gen 3 Prius Main Forum' started by Alex Heo, Apr 10, 2021.
  1. Alex Heo
    Alex Heo New Member
    New Zealand Aucland
    My car is Prius 3rd 2013. The problem is that sometimes a photo error is displayed on the instrument panel. And the small triangle yellow warning lamp illuminates on the right side. It is irregular, not periodic or repetitive. If I translate Japanese, I think it means that can not find key. The strange thing is that there is no problem when driving alone. It usually occurs when other passengers get on or off the back seat. I don't think it's a problem because there's no battery. What's the problem?
    52,854
    there's no battery?
    there is a fob battery, and a 12v battery
  3. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Change your fob battery.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    "I don't think it's a problem because there's no battery" = I don't think the problem is no battery
    (my translation of Kiwi to English).
    But +1 on Jim Swart
  5. fuzzy1
    10,707
    Is the hatch fully closed? Don't just wiggle it to check. Open, make sure nothing is getting trapped in the latch mechanism, then close it very firmly.
    At least, that is a common Gen3 U.S. problem, and the message tends to appear with bumps in the road, or around corners. Don't ask for the logical connection between the problem and the displayed message, we haven't figured it out.
  6. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    My 2015 started giving me that key not detected message some time ago and strangely, it ended up being a weak accessory battery (the 12v battery) After I replaced that, I never got the message again. I did replace the keyfob battery first but it didn't stop the warning.
  7. Alex Heo
    Alex Heo New Member
    New Zealand Aucland
    Oh, thank you. Let's change the 12V battery first.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    While that is not a bad plan, necessarily, a battery for the FOB will be a lot cheaper.
    Do you have two FOBs ?
    Does it do that with both of them ??
    Jim Swart likes this.
  9. bettergolf
    495
    370
    Sanford NC
    I guess you don't know how to check a 12v battery, so just replace it and see if that works. Duh! I also said I REPLACED THE KEYFOB BATTERY FIRST. Reading is fundamental.
    Grit likes this.
  10. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Next time, you should try this: (see picture attached)
    I am sure will help you in the future...
      File size:
      64.4 KB
  11. Alex Heo
    Alex Heo New Member
    New Zealand Aucland
    Yes, the two FOBs, I have are in the same situation.
  12. bisco
    52,854
    if it's the original 12v, you might as well
  13. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Do you keep your fob by your wallet? Credit cards nowadays have RFID chips in them and it can block the signal on your key fob.
  14. Johnny Cakes
    1,065
    789
    Virginia, USA
    Tough crowd.
    Paul E. Highway and Hybrid Ron like this.
