Key not recognized after inverter pump fail
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jarrad reddick, Jun 7, 2026.
  1. jarrad reddick
    jarrad reddick Junior Member
    23
    atlanta
    2007 prius was running, key in slot, hood was up. noticed smoke from just below fuse box (assuming it was the pump) and turned off. Checked under hood and couldn’t tell anything. Tried to start back and car no longer recognized the key. The door ajar alert works, as does the headlight indicator and some other things but NOT the windows and not the fob unlocking doors (but not sure if it ever did). Tried smart key button, touching fob to start button, jumped 12v (from front and from rear), changed inverter coolant pump, put new 15a fuse (for some odd reason I had a 10a there instead of 15). Dealing w this for past 6 months now and forgive me but I did NOT think to check the fuse when it first happened (not the daily driver and I have several gen 2s so the details are sketchy). 3 months ago Was out of town and sent an associate to fix and he said he changed the pump but upon my return car was in same state (not recognizing the key) so I swapped a known new pump just to be sure (and kept the old). Associate has been out of contact so can’t ask him much at all. Will change the fob battery and try again just to see, since it’s been so long
    #1 jarrad reddick, Jun 7, 2026
  2. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    I'm not sure why we keep swapping pumps thinking that has something to do with key recognition very strange make sure 12V is . And pump and am2 fuse good . Of course you need to make sure your key fob battery is good and so on a red light ignites when you push any of the buttons on the fob upper right corner if not. Those issues may need to be dealt with
  3. jarrad reddick
    23
    atlanta
    Thanks a million. Will do. Only reason why I suspect the key issue has something to do with the inverter : the smoke I saw. That was the only clue. Nothing else changed and it was instantaneous. Things were fine; and then they weren’t. I had been driving the car all month. Very odd
  4. Tombukt2
    13,861
    2,519
    Durham NC
    It won't necessarily be the key not being recognized with the am2 fuse blown the car can't start at all no matter what fob does. And if it goes in the slot it should turn the security light off and you should be able to make the car ready that doesn't guarantee engine running . But it means it's capable of running if all is correct air fuel spark etc .
  5. jarrad reddick
    23
    atlanta
    I just re-verified that the fob battery is good (red light ) and the am2 15A fuse is good and the pump is currently not connected and jumping 12v using jump box at rear. Same results (I know the electronics aren’t totally dead bc the door ajar alert and a few other things are still working
  6. jarrad reddick
    23
    atlanta
    Updated : the key recognized now. I’m not sure what did it: changing the fob battery, actually touching the fob to the start button, ensuring strong jump, etc. And now the struggle will be to get the Ready to come on (and to resolve this red triangle)
  7. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    It's time to connect a scanner and read the trouble codes.
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,107
    6,969
    Texas Hill Country
    More than one fuse blows.
    Why isn't the pump connected? The system can tell its not connected and may disable the hybrid system. The inverter, mg1 and mg2 are all cooled by that pump.
  9. jarrad reddick
    23
    atlanta
    Thank you for this. The scanner shows no codes; even with the triangle present. Clearing the codes does not resolve
  10. jarrad reddick
    23
    atlanta
    The pump was not connected so as to eliminate that variable. I’ve since connected it. I’m pretty sure in one of the other gen2 vehicles in was able to get it done that way (but notes have been destroyed so I cannot be 100%). I wonder which other fuses might blow. At this point I have the car recognizing the key; just trying to get the Ready indication now. I am appreciative of this [and all other] feedback
  11. jarrad reddick
    23
    atlanta
    UPDATED: waited ten minutes with 12v disconnected and that worked. Note that the triangle came right back but by then the car was started. I’ll leave this post up
    in the small chance that it might help someone in the future (maybe even me)… Daily driver (no glaring issues with this one) but I had seen the red triangle yesterday while driving (code said hv issue) and made the note to look further into it. Today I’m on my way to autozone and made quick stop. Upon returning to car, I get triangle and no ready. Normally think clearing the triangle would allow me to at least get the Ready so as to get home… but I absentmindedly left my scanner in one of the other cars. At this point, stuck and need to find a way to get to Ready. Unplugged -reconnected positive terminal, pressed start twice, held down start, … Wonder what are some other hacks to try. This is a gen2 other than the one posted earlier this week (where the key was not recognized)
    #11 jarrad reddick, Jun 9, 2026
  12. jarrad reddick
    23
    atlanta
    Maybe try the safety plug on the hv? It’s pouring rain. Might not be safe but that might reset whatever the fault is/was. Either that or walk home… or continue to google and wait for the Priuschat gurus that have been saviors in the last…
  13. Tombukt2
    13,861
    2,519
    Durham NC
    Sounds like you may have an HV fault isolation fault so on and so forth usually a cheap scanner clear the code twice get you started again and running ready ETc. bit won't stay that way .
  14. ChapmanF
    19,025
    ^ This worked (as you saw) to get the ECU to forget it knew about the fault.
    ^ Not this. Unhooking the 12-volt battery worked, because the ECU memory is maintained on 12-volt power. The safety plug interrupts the high-voltage system, which is separate. ECU memories do not get their power from that.
    You didn't reset anything that the fault is/was. An ECU noticed that a fault exists, and you cleared the ECU memory of having noticed that fault. That was enough to let you start the car again, but the real thing you have to do is find and fix the fault.
    Isolation faults somewhere in the hybrid system, as Tombukt2 pointed out, are programmed with the kind of fail-safe behavior you're seeing: they don't shut the car down if detected while operating, but they do prevent going READY next time.
    So we could probably guess that, when you read the trouble codes, one will be P0AA6. Still, reading the actual codes beats guessing. And if you do have P0AA6, the 3-digit INF code that goes with it will help you narrow down where to look for the fault.
    Brian1954 likes this.
  15. Brian1954
    2,686
    1,073
    If the scanner does not show any trouble codes when the triangle is on, it means that your scanner can not communicate with all the ECUs in the car. You need a better scanner.
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    You want a scanner that can communicate with all the ECUs in the car.
    I recommend the Autel AP200 scanner. It is an OBD2 Bluetooth dongle that connects to the OBD2 port in the car. You install an Autel app on your phone or tablet. It costs about $60 on Amazon.
  16. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Got an alignment last week and fob worked fine driving home. Later that evening the fob was unable to unlock the door by proximity nor using the fob buttons and I resorted to using the physical key and inserting the fob into the slot to operate the car. The fob's red led would flicker when buttons were pressed. Took the fob apart and the battery measured 2.6V so I installed a fresh battery and it was working again.
  17. Tideland Prius
    16,680
    Threads merged
  18. jarrad reddick
    23
    atlanta
    Thanks to all for the support here!
