Key Stuck in Prius - won't turn on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shah, Jun 9, 2010.
  1. shah
    shah Love My Prius
    43
    Houston, TX
    Finally I got time to take a look at it. I was going to jump start it. But guess what I did not find the small metallic plate to which I was supposed to hook up my cable clamp.
    I have attached the picture. Looks like it is missing. However I do see a metallic screw coming out with a nut on top. I am not sure if that's part of the terminal as well or not. Now it may be as simple as the metallic plate is normally hooked up to that screw and I am simply missing it, or worst case that I am missing the wiring that brings the battery terminal up front.
    Could someone take a look at my picture and compare it with their Prius and let me know what's going on here?
    Thanks.
  2. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    The actual post on your car is missing. It goes above the bolt in the slot. No problem though, attach the plus (red) lead to the threaded bolt part, and the black (ground) to a bolt on the strut tower.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Thanks for the reply but I doubt I will have any chance getting a new battery for free. I bet they will do a battery test, the weak battery will pass the test, and they will show me the door. ;)
  4. shah
    shah Love My Prius
    43
    Houston, TX
    I jump started the car. Everything went good. I drove it for about half an hour. Came back home and stopped the car. Haven't started the car again. But checked the voltage and it is showing 12.5V. I wonder if that's ok or it was supposed to show above 13V. Does anyone know how much it should show after being driven for 30 min.
  5. shah
    shah Love My Prius
    43
    Houston, TX
    Ok. I started it again after almost 6 hours (read the above post). It turned on and started just fine, but the MAINT REQ'D light was blinking for several seconds in the beginning. Not sure if it means that the battery could be weak. Will have to search around. Please let me know if you already know. My manual hasn't arrived in mail yet.
  6. Patrick Wong
    18,210
    6,517
    This means that at least 4,500 miles have elapsed since the MAINT REQD odometer timer was last reset. The light will appear solid after 5,000 miles have elapsed, and this means that you need to change the engine oil and oil filter. The light has nothing to do with the 12V battery.
    Try measuring the 12V battery voltage again tomorrow morning, before you make the car READY. The idea is to see what the voltage is after the surface charge has dissipated.
  7. shah
    shah Love My Prius
    43
    Houston, TX
    OK. Thanks for the information. Will measure it tomorrow morning.
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    There are ways of stressing the 12V battery, since it is relatively puny to start with, this is not difficult! Now on a battery that has already given you problems it is even easier. Should you happen to be in the Toyota waiting line and have car in standby ( accesory mode ) the 12V charging system is not working. Should you turn on every possible drain you can think of, with any luck you will be able to not start the car and Toyota will have to drag thier charger out, so they can move your car aside, out of the line. Some people may think this is sneaky and unfair. I would like to point out that on a normal car with a substantial starting battery one can easily do this sort of procedure for at least 30 min without the battery running empty. And if Toyota properly addressed this issue you would not be in line to start with. After visibly proving that the battery has a fault to the service writer, mechanic one should be able to present clear cogent reasons why Toyota should provide a new free battery.(this: on a relatively new car, 1-2 years old ) Always be polite, diplomatic and soft talking.
  9. shah
    shah Love My Prius
    43
    Houston, TX
    After being parked for almost 24 hours I measured the battery voltage again and it showed 12.07V. I tried to turn it on and it did. After a couple of minutes (without driving) I accidentally turned it off. I was afraid, but then I tried to turn it on again and it did turn on again. I drove it for about 10 to 15 min and then measured the voltage again and it was showing 12.37V.
    So does it mean the battery is all charged up and good?
  10. Patrick Wong
    18,210
    6,517
    12.1V is not very good, as that means the battery is 30-40% charged. You had charged the battery for 30 minutes after jumpstarting. I think the battery needs to be charged for 8 hours or more if you want the charge level to approach 100%.
    If you have a battery charger, then I suggest you hook that up and let the battery charger work overnight. Otherwise I suggest that you plan a long driving trip or at least leave the car READY for most of a day (the car does not have to be driven.)
  11. andyprius
    2,212
    188
    I agree with Pat, your readings are questionable. But, keep working on it. In the meantime you may want to make plans for purchasing a replacement. Afterall, one day you may urgently need one.
  12. shah
    shah Love My Prius
    43
    Houston, TX
    Thank you guys for advice.
    Could anyone be kind enough to take the closeup photo of the fuse box? I wanna see how the battery terminal plate looks like and how its hooked up to that screw (as shown in the photo attached to one of my posts above). I want to fix that part before I take it to the dealer (in case if I have to take it to the dealer) or the dealer might get suspicious about it and I am afraid they might void the warranty or something. You know after all I bought this vehicle used.
  13. andyprius
    2,212
    188
    You can go to the dealer at any time, either in service or parts and they will be glad to answer any and all questions. No appt necessary. They will not get suspicious. They will not note your Lic plate # This is not China or Russia. In fact if you are really paranoid about this, go test drive a 2010 and then ask the salesman about your concerns. The Gen II and Gen III are quite similar.
    :cheer2:
  14. 2009Prius
    2,705
    512
    63
    If still needed here is what my fuse box looks like:
    Good luck! :)
  15. dahmshl
    dahmshl Junior Member
    Milwaukee, Wi
    I have had the same problem with my 2005 Prius. This has occurred three times in the last two months under various weather conditions. The entire panel lights up, auxiliaries work, radio, lights, etc. There is a warning message reading: The transmission lock is abnormal. Park in a flat place and apply brake. This doesn't make sense as I am parked in a flat place and couldn't move as the engine won't engage. I have had AAA jump the battery and the car still would not start, but minutes after AAA left the car started seemingly of its own volition. I have taken it to the dealer twice and when they put it through their diagnostics, they found nothing and said the battery was okay. Any suggestions??
  16. Patrick Wong
    18,210
    6,517
    It's a waste of time to have the dealer check your 12V battery. Especially if the 12V battery is original equipment or more than 4 years old, replace the 12V battery now.
  17. dahmshl
    Milwaukee, Wi
    Why do you say it's a waste of time??
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Probably because a lot of people have had similar problems that were only resolved after the 12V battery was replaced. The test that their dealers ran on their battery said the battery was OK, but it really wasn't.
  19. richard schumacher
    7,683
    1,066
    United States
