Keyfob A/C button works
Discussion in 'Prime Main Forum (2017-2022)' started by bwilson4web, Jun 14, 2017.
  1. bwilson4web
    16,519
    Alabama's traditional high humidity, hot summer weather arrived this week. Based on earlier experience with the 2003 Prius, I only used the A/C when it got especially close. But I needed to run an errand at 2PM and I knew the car and drive would be insufferable. So I finally hit the "A/C" button on the keyfob while getting dressed.
    I was pleasantly surprised that the cabin was nice when I got to the car, the lowest trim "Plus." Then this evening while standing by the car, I hit the button and was happy to watch the car A/C come on and the EVSE light up to sustain the charge.
    Now our BMW i3-REx has something similar via the cell-network based car connection. I had a strange problem where the App reported it could not send the A/C enable only to find when I got to the car, it was on.
    Regardless, having the keyfob "A/C" work is an important feature in a hot climate and I expect to use it more often in the future.
    #1 bwilson4web, Jun 14, 2017
    Bob Comer and stevepea like this.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Nice, same with PiP.
    Just remember that the degree of cooling depends on the temp setting when last driven. If you go into a restaurant leaving the car parked exposed to the sun, lowering the temp setting before shut-off will enhance cooling effect of the remote A/C operation afterwords.
    dalcon95 likes this.
  3. MNdriver
    MNdriver Senior Member
    549
    577
    How far away will the fob work? i thought it worked only in close proximity.
  4. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    With the PiP and FOB battery in good conditions I managed to operate it even 70-80 yards away (with eyesight).
  5. MNdriver
    549
    577
    Cool! (Maybe even lierally). I'll try it.
  6. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    How do you know it worked?
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    she's the bionic woman:D
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Car confirms receipt of signal by blinking.
    MMBH likes this.
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Only when she's in the right temperature (Oops...temperament) range(n)
    priuscatprimeguy likes this.
  10. MNdriver
    549
    577
    Is "A/C" the Japanese definition, i.e. climate control? So I can start warming my car with a press of the key fob in the winter?
    MMBH likes this.
  11. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Yes, but since you have the Advanced you can use Entune App and not have to worry about what setting you left your car in. The app lets you choose various things like Flame Thrower heat or Front Defrost and/or Rear Defrost, along with just Snow blizzard cold... if you want.
    MMBH and priuscatprimeguy like this.
  12. priuscatprimeguy
    2,730
    2,640
    contrary to popular belief A/C (air conditioning) does not simply mean "to cool" hence the word "conditioning":eek:
    MMBH and mercat68 like this.
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I never found the function useful since the car is garaged. Range and line of sight in a parking lot is so short that by the time I walk up to the car, it's hardly more cool than if I rolled all the windows down a for starting the car.
  14. stevepea
    stevepea Senior Member
    535
    581
    While I'm not a big A/C user, and probably won't use the pre-AC myself, I can certainly understand the need for it in hot, humid climates. Glad to know it works well, should the need arise.
    giora likes this.
  15. MNdriver
    549
    577
    Yeah, I'm aware of the Entune App. Even tried it once, without success. But I've read that the pre-conditioning through the app works only where you have 'sufficient' (whatever that means) charge in your battery. And since I can't charge at home, that will rarely be the case. I thought maybe the fob isn't quite so fussy as to when it will work.
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    The term "air conditioning" pretty much universally means "cooling" to North Americans, and always has, regardless of the literal meaning of the words. If one were to tell someone in the middle of a Minnesota winter that you were turning on the air conditioner, you would get a real funny look.
  17. priuscatprimeguy
    2,730
    2,640
    :eek: like this?
    MMBH likes this.
  18. stevepea
    535
    581
    Technically true, though at this point it's come to mean cool. After all, in a lot of the world (Asia), everyone just says "aircon" (= cool)
    English is quite a language. After all, if you think about it, people are "head over heels" for everyone -- because unless you're upside down on your hands, your head will always be over your heels...
    #18 stevepea, Jun 14, 2017
  19. priuscatprimeguy
    2,730
    2,640
    Probably because when Carrier invented the air conditioner to cool, people weren't using air conditioners to heat
    pilotgrrl likes this.
  20. Admittedly, while I was reading about the A/C button on the key, I wanted to get clarification about how I know if the defroster will "just know" to kick on in the morning (will it sense it? Or do I need to pre-set the defroster the night before so that when I press the A/C/ button it turns on the defroster and not just the air conditioner?).
    Then I searched online and found your post... I was totally not even aware that I could do that through an app. (Also I admit to not using a smart phone, for years I've stuck with an iPod Touch and free WiFi cause I gotta save money somewhere.) So, I figured, well let me enter in my TSC contract ID, and see what happens.
    Well, what do we have here? :D
    [​IMG] [​IMG]
    #20 Deleted member 111882, Sep 22, 2017
    alexcue likes this.
