Keyfob Emergency Key missing
Discussion in 'Gen 3 Prius Main Forum' started by Bryanto1, Jul 15, 2014.
  1. Bryanto1
    Bryanto1 New Member
    Honolulu, HI
    I just bought a used 2011 prius from a toyota dealership and noticed that both keyfobs are missing the emergency key. Is the emergency key a factory option or does it come with all keys (standard)?
  2. robertk328
    robertk328 Member
    206
    36
    Should have come with it. I would ask then to have one made for each fob. Did either have a small metal plate on the keyring? That should help them but not sure what they would have to do otherwise.
  3. JC91006
    16,832
    8,603
    I'm thinking the VIN# on the car would be sufficient for the parts department to make the metal key. It should be attached to your key fobs, come as 1 unit.
  4. Bryanto1
    Bryanto1 New Member
    Honolulu, HI
    Awesome. Thank you for the info . :)
  5. robertk328
    robertk328 Member
    206
    36
    You're welcome! Enjoy your new (to you) Prius! I've had two and really like it :)
    I figured the vin would be enough but the keys come with the little tags.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Members here have reported that the emergency key needs to be laser-cut. You might be sent to a locksmith with that equipment.
  7. frodoz737
    frodoz737 Top Wrench
    4,724
    2,518
    33
    Someone at the Dealership knew they were missing. They know how and should provide the missing replacements "without cost" to you. Be nice, but be firm.
    #7 frodoz737, Jul 15, 2014
    hybridbear likes this.
