Keyfob or SKS system
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ritzy4runner, Jul 7, 2016.
  1. Ritzy4runner
    Ritzy4runner Junior Member
    39
    Bremerton, WA
    Have 2007 Prius 3 with keyless entry/start. Recently I had an issue with the fob not working so I installed brand new battery and still nothing. Checked both batteries and they both were reading accurate voltage readings. I went to Toyota and it was going to cost me almost $300 to have the system troubleshot and new fob purchased and programed. I opted to have a key made from the VIN and have been just using the key to open the doors and plug the fob in to start. then the other day I forgot to pull out my fob and the door unlocked and the keyless start worked. The next day it reverted back to using the key and plugging in the fob. About two days ago, it started working again.
    What could be causing this? Do I need to get another fob and program it when it is working? I could really use some help (and no I do not have another fob)
  2. JC91006
    16,937
    8,647
    Do you have any stuck buttons on your keyfob? buttons that don't spring back up after your press them?
    The sensor at the door is different than the sensor that starts the car. If the doors are not unlocking but the car can still start via smartkey function, then the door sensor is at fault. But if both the door function and start functions don't work, then it would be something else.
    The something else would be the sks switch under the steering wheel (by your knee) is in the off position or you have an issue with your fob.....like a stuck button or a bad battery
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Have you checked 12V Aux Battery? I noticed the SKS on my 2009 Gen II starting to get flakey (similar symptoms to those you describe) shortly before the 12V battery died last year! - hope this helps - Wil
    PS: Welcome to PriusChat!
  4. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Did you have to have a new key made from the VIN? There should be one that sides into the side of your existing fob (the handle is where the ring loop is - it pulls out).
  5. Ritzy4runner
    39
    Bremerton, WA
    Thank you. I will take a look at the aux battery. The fob has started working again and has for the past two weeks.
  6. Ritzy4runner
    39
    Bremerton, WA
    I had a new key cut from the VIN which Toyota (my local dealer) made or me free of charge. It was easier to have a full size key on my key ring then trying to keep pulling lut the fob key. thn using thefob inserted in the key slot to start the engine. As I mentioned, the ystem has started working again. I will be checking my aux battery to see if that is potentiall
    UPDATE:
    So I started to have the issue again with the fob not working and requiring to insert it in the key slot. I left for work about a month ago, left my car with my fiance and told her to drive it as she needed to. Seems the day before I am to come home, she went in to start the car and nothing, dark would not do anything. After getting home I too looked at what was going on. Seems the screen was totally dark so that meant I had lost the AUX battery. What a joy that was gettin that battery out. Put it on a 2 amp trickle charge for about 6-8hours. Put back in and drove about 40 miles to local AutoZone to have it checked, they checked it in place and said that the battery was at about 86%. Still driving the car but have to insert the keyfob.
    Found the Diagnositc check and did that. Static voltage is 12.0 VDC, headlights on drops to 11.7. Another interesting issue has ocurred now, my drivers window controls ... the window will not go up or down in auto mode (where you push the button fully and the window goes up or down totally). Do not undertand what is going on.
    While the battery appears to be an OEM Toyota battery I have no idea how old it is. Any further things I can do to check this battery. I hate havin to spend $200+ for a new battery if I don't need to. Really can use some input here
  7. bisco
    52,876
    12 volts is low, a new one is 13 volts. the battery has a date code on top, if your interested.
  8. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
  9. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    The date code is in the center of the battery, usually covered over by the securing bracket. It is a 6 digit number in the form of DDMMYY, where:
    • DD = a two digit day (01 - 31)
    • MM = a two digit month (01 - 12)
    • YY = a two digit year (04 - 16, and counting)
    hope this helps.
    But, why prolong the agony, your voltage readings and the frequency of your battery getting to completely discharged state, pretty much says your battery is toast. Just buy a new one and be done with it.
    #9 dolj, Aug 16, 2016
  10. WilDavis
    2,493
    2,155
    49
    For the Gen II, the power-window initializing operation is described on page 77 of the destruction manual - hope this helps - Wil
