Keyhole cover on driver's side door
Discussion in 'Prime Accessories and Modifications' started by utsug, May 7, 2019.
  1. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Where can i buy keyhole cover on driver's side door for Prius Prime? I looked online but unsuccessful.
    Anybody knows where I can buy this?
    Thank you.
    52,774
    dealer?
  3. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    Nope they don't have it.
    52,774
    weird, and they can't order it?
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    May I ask What is a keyhole cover? :confused:
  6. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    the hole on the driver's side door where you insert the key to open the door.:)
    Salamander_King likes this.
  7. Salamander_King
    11,024
    8,977
    New England
    I googled it. I kinda understand what it is, but I have never seen one. Is there OEM cover for PRIME?
  8. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Cant you just get a passenger side handle and put it on the driver's side? They look reversible (just checked my car). It would shave the keyhole and you wouldnt be able to use it, but you'd get the look.
    In all honesty, how many times have you used the key hole?
  9. bisco
    52,774
    a prius with no keyhole is an impenetrable fortress
    Elektroingenieur likes this.
  10. Elektroingenieur
    2,515
    3,288
    Three Touring
    The metal cover that slides out of the way when the key is inserted into the door is available only as part of the lock cylinder set, Toyota part number 69005-47230, shown in parts catalog Figure 67-12, Lock Cylinder Set. When sold as a service part, it comes with two key blades cut to match, and the list price is $186.63. Installation and removal procedures are in the Repair Manual (more info).
    Just once is enough, since that’s how you enter the car to open the hood if the auxiliary (12-volt) battery has failed or is discharged.
  11. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    I was actually looking for the cover that you just push it into the hole and not fhe fancy ones. My brother has that cover but on his Scion Tc.
  12. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
  13. Salamander_King
    11,024
    8,977
    New England
    That's what I though you are looking for, then I started wonder with others commenting, you actually needed the key cylinder.
    You want something like this, but for PRIME.
    bisco and utsug like this.
  14. utsug
    utsug Active Member
    202
    108
    Palmdale
    2018 Prius Prime
    yes exactly like that (y)
  15. bisco
    52,774
    well done! only took 14 posts :p
  16. Tha_Ape
    271
    162
    Washington, DC
    The cover on my Infiniti made it look seamless. That's why I suggested a whole handle, but looks like a plug is simple enough.
  17. Fawkes
    Fawkes New Member
    Oregon
    Did you ever end up finding this? I'm looking for it also!
    Thanks
