keyless access to hatch
Discussion in 'Gen 3 Prius Technical Discussion' started by kente46, Aug 23, 2012.
  1. kente46
    kente46 Junior Member
    Just traded in my 2006 for a 2012. Can I use keyless entry to open the hatch or do I have to use the fob? When I touch the hatch handle, nothing happens.
    Thanks!
  2. gliderman
    gliderman Active Member
    751
    223
    My son opens it when I am in the car, so I dont know if the car senses the fob or the unlocked state. I keep my fob in my pocket all the time so I dont know if I can open the back without it if the care is in an unlocked state.
  3. fuzzy1
    10,167
    The Two has just one door (driver door only) Smart Key System. To open the hatch with SKS, you need a higher trim level with the three door system.
    kente46 likes this.
  4. Frank Keeney
    Frank Keeney Junior Member
    SF Bay Area
    For 2012, check out http://www.toyota.com/t3Portal/document/om/OM47704U/pdf/sec_01-03.pdf.
    On page 70 of the PDF, there are instructions on how to open all doors when you grab one handle. My Two is able to open all doors when I reach for the driver door handle, after following these steps.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If the hatch lock is released you must push up on the larger rubber rectangle under the handle for a second or so.
    The smaller rubber square is for locking the hatch (actually locks all doors).
    The SKS only comes into effect if the hatch is locked.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    For a price, you can upgrade yours as a DIY. There are instructions/part nos, in a post in the mods section.
  7. bisco
    49,415
    no. you have to hit the fob unlock twice, then open hatch with rubber covered switch.
