Keyless entry finnicky + maintenance notice
Discussion in 'Gen 3 Prius Technical Discussion' started by vmta, Sep 10, 2018.
  1. vmta
    vmta New Member
    New used Prius owner here~
    For the past couple of days my Prius has been showing the "maintenance required soon" notification. That's just an internal 5000 mile timer running out right? Because I got an oil change about ~800 miles ago.
    But just today I noticed that keyless entry wasn't working like usual. I had to touch the lock/unlock part of the door multiple times and it would only work sometimes.
    Two questions:
    1. These issues are unrelated right?
    2. Could it be an issue with my key's/car's battery?
    Thank you!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    The maintenance reminder is based on a 5 k mile cycle and can be reset.
    You can check the voltages of all batteries involved and if they are low, swap them out;).
    Good luck and keep us posted (y).
