keyless entry problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ld9381, Jul 2, 2010.
  1. ld9381
    ld9381 New Member
    New York
    Keyless entry stopped working on driver's door, but still works on passenger door and hatch. Pushing the buttons still works. I already changed the battery in the fob, so it's obviously a problem with the sensor in the door handle. Any ideas what could be wrong? Can I fix it or do I need to take it to the dealer?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    How many miles on your car? If under 36K, it should be repaired under warranty.
  3. ld9381
    ld9381 New Member
    New York
    I think I'm over that probably around 40000
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It sounds like you have correctly diagnosed the problem. You can replace the sensor yourself if you don't mind disassembling the door.
    Tom
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    It does sound like the driver's door handle sensor since the other doors work. It could be as simple as a loose connector at the door handle, or the sensor may need to be replaced. I would think that you should be able to do it if you were to check connections, etc. and not find a problem and then know you will need to replace the door handle with the sensors.
    I know I had a similar problem with a door lock on my wife's 2007 Honda Accord with 38,000 miles and Honda fixed it under warranty even though it was beyond the 36k miles. It may not hurt to call and ask, you may get lucky like I did.
    Let us know what you do to fix it.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    There is info/photos on disassembling the door panel, though not the
    door handle itself, here.
