keyless entry security hack
Discussion in 'Prime Technical Discussion' started by jbhybrid, Mar 11, 2017.
  1. jbhybrid
    jbhybrid Junior Member
    16
    Is this real? Is everyone keeping their Prius keys in the freezer? Why didn't the dealer mention this?
    https://www.nytimes.com/2015/04/16/style/keeping-your-car-safe-from-electronic-thieves.html?_r=0
    "Mr. Danev said that when the teenage girl turned on her device, it amplified the distance that the car can search, which then allowed my car to talk to my key, which happened to be sitting about 50 feet away, on the kitchen counter. And just like that, open sesame."
  2. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Keys/keyless only keep honest people out.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  4. jbhybrid
    16
    What the dealer did tell me was it cost $800 to replace the fob if I loose it. If this is the security I get for that money, consider me unimpressed. It is absolutely possible to make a key that only works within a specified distance to the car, using time-of-flight measurements, for example. Apparently they just didn't feel it was necessary.
  5. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    aluminum foil does the trick well
  6. fuzzy1
    10,150
    Look at the dateline. That is old news, 2 years ago. See previous discussion threads, here are some of them:
    Keyless-Entry Cars Vulnerable to Silent Theft | PriusChat
    Might want to store your PiP fobs in a metal container | PriusChat
    For the vast majority of us, this threat remains theoretical, not a significant part of reality. The threat has increased a bit since then, according to subsequent reports, but this still doesn't seem to be a common problem.
    BTW, don't keep the fob in the freezer or refrigerator. The repeated thaw and warmup cycles predispose the internal electronics to condensation and other moisture problems.
    giora and priuscatprimeguy like this.
  7. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Double wrap the fob in aluminium foil, single layer is not enough. Try walking up to the car and see if it unlocks, if it unlocks try another layer until it will not unlock. Special wireless pouches, often are rubbish, get a recommended one that has been tested by one of the magazines. Otherwise use your Christmas biscuit tin and turkey foil.
  8. CraftyCoder
    CraftyCoder Member
    48
    65
    Washougal, WA
    2018 Prius Prime
    Or you could put the key into battery-saving mode. When in this mode it stops receiving radio waves.
    FuelMiser and walterm like this.
  9. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    rather have them open the door with my key then break the window... if they want to get in they're going to get in. side windows can be broken easily and with little noise (just cover them with sticky paper and use a $10 fire/rescue windows punch tool), the tacky paper keeps the glass from flying everywhere and "tinkling"
