Kicking into Neutral on its own
Discussion in 'Gen 3 Prius Technical Discussion' started by Prius in Nebraska, Mar 21, 2022.
  1. Prius in Nebraska
    Prius in Nebraska New Member
    Omaha Ne
    new to here. We just recently bought a 2012 Prius. So far seems to be good but we have 1 little glitch. Occasionally when coasting it kicks itself into N. It will go days without doing it, but sometimes when it does it, it keeps doing it. The really weird thing is if you hit the power button and then turn the car back on it quits doing it. Any thoughts suggestions on what this is? And then also how do you know when the main battery is getting bad. The dealer told my GF it’s fine but I hat to sit in a drive through for like 15-20 minutes the other day and it went from full to almost empty. Yes I was running heat. Thanks!
  2. JC91006
    16,936
    8,647
    I think there was someone that wrote about having this exact issue not too long ago. Hopefully this is not that car you bought
  3. Prius in Nebraska
    Omaha Ne
    what’s the thread for the one you are mentioning? The only thing I was finding on kicking to Neutral was people doing it to change speeds or something, not the car doing it on its own?
  4. ChapmanF
    18,998
    There was one recent thread where it turned out there were COVID masks hanging from the shifter.
