Kill a Watt EZ
Discussion in 'Prime Main Forum (2017-2022)' started by RonPrime, May 4, 2019.
  1. RonPrime
    RonPrime New Member
    Illinois
    2019 Prius Prime
    A local store has the Kill A Watt EZ in stock. I’m wondering if this is a safe, reliable option to check the number of KWH I use each night during my charge? I’m using a 20 amp wall plug.
  2. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    It’s fine.
    jb in NE likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    Yap, it works fine to monitor the kWh use at the wall. It is rated to max 15A, which works fine for 12A max of the L1 EVSE. I've had it on the wall for almost two years now for daily monitoring of kWh used for charging my PRIME. Just stick with the authentic P3 International product. Power Monitor - Kill A Watt EZ | P3 There are other cheaper knock-off kWh meters out there, but many of them do not have 15A max spec.
  4. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Just curious, why?
  5. Salamander_King
    11,024
    8,976
    New England
    I don't know about OP, but I do it so I have a very clear idea of how much I am spending on fuel (in this case electricity). With gas, you know the exact amount you spend for each fill, but with electricity, it is not that easy unless you have an expensive L2 EVSE that records amount of electricity used for each charge session.
  6. smyles
    332
    229
    US
    2020 Prius Prime
    Compare the last/pre-EV year bill, the difference is your monthly consumption, give or take couple of bux. Or just use car's displayed monthly mileage * miles. The Prime's battery is so small, even with 2-3 full recharges each day it's not that much anyway.
  7. Salamander_King
    11,024
    8,976
    New England
    If you are not worried about a few bucks you spend everyday, then you would not monitor it using Kill-a-watt meter. For me, energy cost spending, or for that matter any spending down to a penny, is a very important to know. That's all.
    FYI, our monthly electric bill fluctuate enough, comparing to different period will not give me even an estimate for the electricity used for charging my car. The car's displayed monthly mileage have no information on how much of that mileage was driven by EV mode using electricity provided from the grid. Furthermore, our electricity rate is very high as to driving EV on PRIME is often more expensive than using gas. If I did 2-3 full recharges each day, which I do not do currently, would end up costing me ~$119/month give or take couple of $. ;)
    #7 Salamander_King, May 6, 2019
  8. smyles
    332
    229
    US
    2020 Prius Prime
    I hear you, I just don't get the importance of knowing if your Prime consumed 198 or 202 KWh last month. What are you going to do with this info?
    And I've meant comparing same month bills from different years.
  9. Salamander_King
    11,024
    8,976
    New England
    If you ever used personal financial management application, like Quicken, you will know what to do with the info. I like to know where my hard earned money are going. I also keep track of every single penny used for my car, including a few bucks I spent on washer fluid and 4 quarters I used for rinsing my car at self car wash. In the end when I am done with the car, I have TRUE cost to own a car. I did that for my last 3 cars so far. Furthermore, the information I have gathered so far is invaluable in planning solar panel on our roof, which I am planning to install sometime this year.
    Also comparing same month bills from different years are no help in estimating use of electricity for charging, at least not in our household. Year to year fluctuation of the same month with or without charging is too large.
    #9 Salamander_King, May 6, 2019
  10. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    The Kill-A-Watt can actually go beyond 15A for a short time (just like a 15A circuit can). I hooked it up to my 15A rated miter saw to see what would happen, and it showed a little over 17A while cutting through some particularly dense wood. The display flashes if the amperage exceeds 15. Obviously it's not rated for over 15A continuously, and it could get too hot if you try.
    Salamander_King likes this.
  11. Biosphere
    Biosphere Junior Member
    Alberta
    2019 Prius Prime
    How many kwh is a single full charge?
    SM-N960W ?
  12. smyles
    332
    229
    US
    2020 Prius Prime
    It's like asking how much milk is in 1 gal jug.
  13. Salamander_King
    11,024
    8,976
    New England
    With L1 (120V) EVSE that comes with the car, at the wall readings have been 6.4-6.8 kWh from EV range remaining zero to full charge. I use 6.6 kWh on average. However, many Prime owners who use L2 (240V) EVSE have reported here their reading for a full charge is 6.1-6.3 kWh. I attribute the differences of ~10% is due to the efficiency difference between L1 and L2 EVSE.
    benagi likes this.
  14. Biosphere
    Alberta
    2019 Prius Prime
    Thanks Salamander. By the way, from your user name, can I deduce that you are an amphibian/reptile enthusiast? :)
    My electricity cost is 6.8 cents per kwh. And a full battery charge runs for 2 days for me. So my monthly cost is $6.73. Previously I used to spend $40 on gas. Now thats something!
    SM-N960W ?
  15. Biosphere
    Alberta
    2019 Prius Prime
    Oh, here is the kicker! My household electricity cost by kwh consumed comes to $61.56. But then all the additions i.e. access charge, local fee, taxes etc. bring the amount up to $151.
    SM-N960W ?
  16. Salamander_King
    11,024
    8,976
    New England
    I think it is a fictitious character in PlayStation game. I never played it, but when I was creating my account here my son was playing on our large screen TV and he told me about it. I used it as a handle, and it got stuck here.
    Do you mean a full charge will last you for 2 days to drive around? Meaning you drive less than 12 miles/day? I usually drive ~40miles a day. Which meant previously I had to put gas every 10 days. Now with ~25-35miles of EV, I need to stop for gas only once a month or longer.
    Yeah, I have seen those bogus billing statements others have posted. Even if the official rate is 6.8 cents per kwh, if you have to pay for all the other "fees", then your true electricity rate is whatever the total monthly payment you make divided by the total kWh you used for that month, IMHO. Mine comes up to be ~$0.2/kWh.
    #16 Salamander_King, May 7, 2019
    Raytheeagle likes this.
  17. Biosphere
    Alberta
    2019 Prius Prime
    Yeah, I drive less than 15 miles a day on average. I agree with your assessment of overall electricity costs. Have not calculated that in my case yet.
    SM-N960W ?
    Raytheeagle and Salamander_King like this.
  18. Biosphere
    Alberta
    2019 Prius Prime
    OK. My household electricity cost (including bogus charges:) comes to 15.1 cents per kwh.
    SM-N960W ?
  19. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I got my kill-a-watt in the mail a couple days ago. My R/T to work is ~25mi and I usually have ~5mi to spare on the display. It takes me about 5.6-6kW to "fill up". At $0.11/kWh my costs are roughly $14/month. A couple bucks more if you include weekend use.
