Kirkland (Costco store-brand) oil
Discussion in 'Fred's House of Pancakes' started by NewHybridOwner, Mar 31, 2020.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,155
    1,767
    Mars Hotel
    Just received my 10 quarts of Kirkland Signature 0w-20 for $27, including shipping via UPS. First time using a "non-big name" motor oil, unless NAPA counts.
    Seems like a great bargain. With my $4 Wix filter = $17.50 to change the oil in my Outback vs. $70 at my local mechanic.
    Oh, my Prius is starting to sip a bit of oil between changes. Not a lot, seems like 3/4 quart in the six month period, but I am keeping an eye on it. Had to drive to Portland early today and it was down about half a quart, so poured in 8 ounces of NAPA 5W-30 Semi-Syn (it was on sale a few months ago).
    kris
    #21 cyberpriusII, Aug 2, 2020
    Montgomery likes this.
  2. Prodigyplace
    12,547
    11,772
    Central Virginia
    You may want to think about installing an oil catch can to keep moisture in the gasses from the pcv valve out of the air intake. Many users here think it can avert a future head gasket failure.
  3. Trollbait
    12,517
    How does that work?
    I've installed one on the Ranger to reduce carbon build up, and it does reduce the amount of oil burned off. Won't help in the case of worn piston rings though.
  4. Prodigyplace
    12,547
    11,772
    Central Virginia
    The PCV valve apparently lets moisture through into the air intake. Over time this can blow the head gasket. They did some changes on Gen 4 that may help. @Mendel Leisk is one user that installed one.
    It basically uses steel wool to trap the moisture where you can empty it periodically.
    One long thread here. Oil Catch Can, Eliminate that knock! | PriusChat
  5. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    NAPA has a deal on their oil and filter but in fact does not rate their own oil as the top choice for a 2015 Prius.
    I just bought 5 qts of Mobil 1 0W-20 at our local regional-chain supermarket for $22.xx, and my online submission of my $10 rebate claim has been approved.
  6. Trollbait
    12,517
    The moisture in the crankcase mostly comes from combustion of the fuel. The PCV is there to let that water vapor escape, and some portion of the oil also vaporizes and vents out. Before those vapors were routed to the air intake, car engines just vented it to the atmosphere.
    I've only ever found oil in my catch can. I doubt it gets cool enough to condense any water vapor out in quantities of note.
  7. Mendel Leisk
    41,396
    With our cold/humid winters I get water froth in the Catch Can when I do spring dump, about 50/50 water/oil. It separates after a day or so; you see distinct layers.
    Trollbait likes this.
  8. Trollbait
    12,517
    My winters are generally dry. If there isn't any sign of water in the crankcase, then it is getting boiled off. Which is what you want
    What I am really trying to get an answer to is how this extra moisture in the air leads to blown head gaskets? It is only a small portion of the intake charge.
  9. Mendel Leisk
    41,396
    Yeah I doubt it does contrib to head gasket failure. More likely piston ring fouling, since the engine is combusting all this detritus.
    Prodigyplace likes this.
  10. bwilson4web
    16,201
    I keep forgetting it isn’t virgin olive oil.
  11. Trollbait
    12,517
    This might be why your oil changes are every 5000 miles.
  12. NewHybridOwner
    607
    283
    W. Michigan
    And I just got my $10 VISA e-card.
  13. Stevewoods
    Stevewoods Senior Member
    659
    1,130
    Seattle, WA
    Seeing this post reminded me, I needed to change the oil.
    So, going to parts store, buying oil, sending in rebate, waiting for rebate....
    or
    Ordering from Costco and getting 10 quarts in four days at my doorstep...
    Guess which way I went. I am good for a bit. :D
  14. cyberpriusII
    1,155
    1,767
    Mars Hotel
  15. ETC(SS)
    7,139
    Pends on your throughput. ;)
    When you guzzle wine, it just doesn't make sense to pay for the bottle yank out the cork every time you want to imbibe....
    I came upon a 6 gallon "enviro-box" of 5w30 that I still use for my pickup and Wally had on the clearance aisle for $20.
    Less than $1 a quart....
    For that kinds of savings?
    I'm happy to measure it out!!!
    For my new GMC they spec 0W20 and I've decided to use the 12q boxes and stick with a 5,000 mile OCI.
    I use Wally's "Supertech" brand and can usually find it for less than $30.....probably made in the same plant as Kirkland's (non olive) oil.
    Wally stocks my OEM oil filters too and I can have them delivered as a part of my weekly grocery run.
    :cool:
    cyberpriusII likes this.
  16. Trollbait
    12,517
    Some non-cheap wines sell boxes now. They do so because the bag collapses as the wine comes. No air gets in, which would ruin the wine over time.
    That oxidation will also degrade motor oil over the time such a large volume would last for most.
  17. cyberpriusII
    1,155
    1,767
    Mars Hotel
    There are a few O.K. wines that come in the bag -- hey, what about botas! --
    But, that took many, many years, and only a few wineries have gone that way. With wine, if I "pour" six ounces when I meant to pour five ounces, well, not much damage done (unless I run a bar).
    Motor oil, amount is much more important and I don't need another hassle when I am changing oil.
    kris
  18. Trollbait
    12,517
    I guess it would be more of an hassle pouring from a box into the engine, even with a tap. Though measuring out quarts means not overfilling.
  19. ChapmanF
    18,136
    Yeah, but the bag gets stiff in cold weather, then you don't know how much wine you've got left.
  20. cyberpriusII
    1,155
    1,767
    Mars Hotel
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    Oh, wait, you can always Shake it Sugaree!!
    #40 cyberpriusII, Aug 17, 2020
    ETC(SS) likes this.
