Klean Diesel Kaput
Discussion in 'Diesels' started by bwilson4web, Mar 3, 2010.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Mainstream Prius has sold in millions and you can not compare the cost with it.
    Diesel PHV would still need expensive emission control. Making it a hybrid does not necessarily make it cleaner when the Diesel engine is running.
  2. bwilson4web
    16,533
    The hybrid drive could ease some of the diesel emissions challenges by avoiding the worst regions. Derating the diesel is possible because the hybrid drive can provide surge power and avoid inefficient diesel regions. But getting the right mix will be tricky.
  3. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Is Atkinson cycle possible in Diesel? I mean keep the compression ignition but it would have the expansion ratio higher than the compression ratio. More work can be extracted out of the fuel.
    The compression will be lower due to late closing of the intake. Will that reduce the Diesel thermal efficiency due to lower compression?
  4. ems1
    ems1 New Member
    55
    MN
    Low compression and diesel is not a good mix unless you are going for a competition only type vehicle
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    With diesel you already have a long power stroke, due to the long compression stroke.
    Tom
  6. Flying White Dutchman
    4,376
    313
    so these urea injects do not need a PDF or EGR?
    or have those cars al of them?
  7. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    All diesel cars here have a DPF and EGR. The DPF is for reducing particulates, while urea and EGR are to cut NOx. Using urea means less EGR is needed, which leads to fewer fuel consuming DPF regenerations.
  8. durallymax
    durallymax Member
    142
    Under The Hood
    ^^^ exactly.
    Lowering a diesels compression ratio probably won't work well. Diesels rely on heat to create combustion, lower the compression ratio and you will loose that heat.
    The new wave of piezo injectors allows the engines to burn all of the fuel an eliminate inefficies and emissions even further.
