Klick Wrench
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Apr 10, 2022.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,254
    942
    So my oil filter was on very tight, so tight it broke the tool I had to do the job.
    Then I found Klick Wrench a torque limiting wrench that will prevent issues like this.
    Below is my broken tool and my new one.
    Klick Wrench had no problem taking off the stuck oil filter and did not break with its solid contruction, then I had the confidence knowing I would not over tighten the filter with the built in torque limiter. 20211108_133507.jpeg 20211121_154739.jpeg
  2. AzusaPrius
    2,254
    942
    Priceless to have in your tool box
    I will link the product in a bit.
    #2 AzusaPrius, Apr 10, 2022
  3. AzusaPrius
    2,254
    942
    Here is the link to the one I purchased.
    <a target="_blank" href="
    ">Klick Wrench Oil Filter Wrench</a>
  4. Mendel Leisk
    42,315
    It will prevent issues like this, because you can't overtorque? Just using a torque wrench accomplishes this, and you can choose the torque value. And, like a lot of these, it's aluminum:
    I've been using the simple, heavy-gauge, stamped-steel Honda socket, since 1990; never had an issue. Also, I don't understand the rational of the extended sidewall down into the zone with stiffeners (not on spin-on stye btw); it doesn't really accomplish anything.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    marked filter cap.jpg It's for total amateurs.
    My husband's friend marked his filter when it was correctly torqued with a white paint marker. For each subsequent change, all he did was to tighten the cap until the cap lined up again with the mark.
    #5 Georgina Rudkus, Apr 11, 2022
  6. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    $50? Way too expensive that adds further insult to injury when it comes to the imbecile at Toyota that unwittingly normalized the use of impact drivers on oil filter cartridges that don't comply with standard oil cap removal wrench, but is slightly off/proprietary. The first few years of Gen3 Prius sucks in almost every way! So much unneeded complexity and hassle in every way! I can't stand early Gen3 Prius! It's an insult to the simplicity that made Gen2 great!
  7. AzusaPrius
    2,254
    942
    I actually just saw a recent post from someone else who had the same issue, the oil filter was on too tight, so it happens a lot from people going to oil change spots or even the dealers.
    Nice trick with the white line for your husbands friend but what about your prius?
    What if you dont have multiple tools like Mendel?
    I like the idea of it being one tool and preset torque to the make and model of my prius.
  8. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    I converted mine to the spin on filter in 3017. Never looked back.
  9. Dagoba
    Dagoba Junior Member
    25
    Bellingham, WA
    So far ahead of your time...
    xliderider likes this.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,065
    6,934
    Texas Hill Country
    In the year 2525, if man is still alive
    If woman can survive, they may find
    In the year 3535
    Ain't gonna need to tell the truth, tell no lie
    Everything you think, do and say
    Is in the pill you took today
    In the year 3017 Georgina is still spinning her gen3 filter
    Not that it matters
    They stopped making head gaskets and brake boosters for it in the year 2525
  11. PriusCamper
    13,440
    5,426
    Yes, that was me with a Gen3 last week...
    Gen2 are so simple! Changing spark plugs, cleaning the throttle body and mass air flow sensor, new filters and oil change is so straightforward and easy.
    Yet doing that in an early model Gen3 is more than twice as much work to do the exact same thing. There's an essential design principle that Toyota massively failed on when it comes to the "advancement" of the Prius line:
    "Keep it simple, stupid (KISS) is a design principle which states that designs and/or systems should be as simple as possible. Wherever possible, complexity should be avoided in a system—as simplicity guarantees the greatest levels of user acceptance and interaction." https://www.interaction-design.org/literature/topics/keep-it-simple-stupid
    Foxglove likes this.
  12. Mendel Leisk
    42,315
    I don’t know of anything other than the piston rings (changed sometime in 2014 model year) that changed in 3rd gen. Oil filter is always the same, permanent housing.
  13. PriusCamper
    13,440
    5,426
    Are you kidding? In a time of engines going 300K miles with nothing more than an oil change and spark plugs, the early Gen 3 engine blows headgaskets, has failed piston ring design and an EGR valve that easily gets fouled and fails, which causes all kinds of other issues.
    Just to do the spark plugs there's over a dozen bolts and fasteners in hard to reach spots just to pull the entire windshield assembly and cowling off, which is a step that you don't have do on Gen2 to do spark plugs. What's more, there's way more hoses and wires on Gen3 in the way of the air box assembly which is made from 4 times as many parts as the Gen2 assembly.
    And then there's the underbelly pan nonsense... On the 2017, the Prius C and Gen2s I've worked on you just put the car on ramps and undo the drain bolt and unscrew the oil filter. But on Gen3 there's constantly lost fasteners that are replaced with non compatible fasteners that you have to figure out. And then when it comes to cleaning the engine compartment, good grief! A gen2 takes almost no time to clean, but a gen3 seems like they almost designed the engine compartment to make it massively time consuming to clean because they wanted us to give up in order for the engine compartment to look as ugly as possible.
    And maybe with a little practice after doing it a few times it's not a big deal, but if you bid a job to do a tune up on a Gen3 because you have lots of experience doing them quickly on a gen2, you'll be taking apart and cleaning and removing so much junk the first time around that it's a time losing and money losing nightmare!
    #13 PriusCamper, Apr 11, 2022
  14. rjparker
    11,065
    6,934
    Texas Hill Country
    Mendel would not have anything to talk about if Toyota didn't add the screwed up egr on the gen3. No one has ever changed or cleaned a gen2 egr. The rings were better on gen2 and did not require a rebuild to remedy.
    PriusCamper and Mendel Leisk like this.
  15. Mendel Leisk
    42,315
    Later 3rd years are not any better, my 2 cents.
  16. AzusaPrius
    2,254
    942
    KlickWrench.com is stocked up and ready to go with the perfect tool for your prius or other vehicles.
  17. PriusCamper
    13,440
    5,426
    You're literally 10 times more prolific at affiliate link work than every last one of us combined. Someday you oughta write up everything you've learned about it and when it has served you well versus when it was a waste of time. Almost everyone I know has failed at affiliate links, but obviously you're the opposite of that, or so it seems?
  18. Mendel Leisk
    42,315
    $40 for a one-setting torque wrench? At least provide a link, not just a phone screen-grab?
    Technical question: does it slip/click at 25 n/m (aka 18 ft/lb) in both directions? That would necessitate another oil filter socket, for removal.
    addendum: also, it’s a single purpose tool, would be too much torque for the spin-on (13 ft/lb) for fourth/second gen, and third with the conversion.
    #18 Mendel Leisk, Jun 15, 2023
    Georgina Rudkus likes this.
  19. PriusCamper
    13,440
    5,426
    OP doesn't have time for all the... They too busy chasing affiliate link opportunities. Being the record holder requires focus!
  20. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    For me the sell on a new filter wrench, besides not having the stupid notched extension part, would be ease of removing the filter housing from the tool, especially when unscrewed from the car.
