knob costs $700 to replace?
Discussion in 'Gen 2 Prius Technical Discussion' started by infael, Jan 23, 2008.
  1. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    NO NO NO NO NO !!!!! DO NOT USE BRAKLEEN you will melt it! WD 40 in moderation should do you fine. If it is going to free up with a spray, that is what i would use.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    We use a lot of cleaning products from American Polywater, which are great for industrial use in Motor Control Centers, and utility switchgear
    For cleaning the shift joystick, I'd recommend their FD product. It's supposed to be safe on plastics, at least it has been on the industrial nylons that I've managed to overspray
    Type FD&#174 Fast Drying Electrical Contact Cleaner -- A Powerful Aerosol with Quick Evaporation that Cleans Cables, Contacts, Circuit Boards, Controls, Relays, Switches, Electronic Equipment, Parts, Tools, and other Industrial Maintenance Items.
    We've also had good luck with HF from CRC
    CRC Industries Global Home
    I'm leery of using any lubricant in electrical/electronic devices. They tend to attract dust from the environment and will usually cause further problems down the road. Utility switchgear or MCC relays that *do* require lubrication, I've had fair luck with this product from Stoner
    Electrical Cleaner and Lubricant factory-direct from Stoner
    Never use anything like carb or brake cleaner near automotive interior plastics.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i wouldnt use WD-40 either... its track record with plastics is not good.
    look at dry graphite based lubes... (expensive but useful for a lot of things)
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Don't use graphite to lubricate an electrical switch!
  5. Qlara
    Qlara New Member
    488
    I don't see why not using WD-40.
    It is mild enough to lub the stuck joints and won't do damage on the plastic. Just keep a Bounty (Paper towel) to wipe it clean after spraying.
    And we are not talking about 'SOAKING' it with WD-40 here, just a light spray should do fine.
    I have used WD-40 to unstuck certain plastic joints/switches and never have problem. (Again, wipe it clean after spray). So I'll still stand by my previous comments.
    NO Brake Cleaner or thick lube.....those are not really for plastic electro-mechanical equipments.
  6. infael
    infael New Member
    Colorado Springs
    My wife does not want me to try to fix the problem myself. She made a good point about the possiblity of something somehow going wrong and us having to get another car when we can't afford it. She'd rather foot the bill than risk having to get another car. Sigh.
    Toyota will reimburse for half. But still...
    Since Liberty Toyota mentioned a popping sound, I asked my wife to listen. She's never heard a popping sound, which makes me wonder if Liberty is pulling my leg. Furthermore, the knob hasn't been sticking lately.
    I sure wish I knew enough about cars (or the Prius) to determine what's going on with the car. The unit is getting replaced this Monday.
    Regardless, thanks for your help guys!
    infael
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    squirting a little graphite in there can't possibly hurt the rest of the car, but it's your $350 and it is probably worth it to keep the wifey happy...I can relate.
