Knock knock
Discussion in 'Prius c Technical Discussion' started by Max Taiwan, Mar 24, 2019.
  1. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    I guess this has been covered a load of time but can't seem to find a fix for it. So here is another!
    Same issue as everyone knock knock when cold which will go away after the engine warms up, until Knock again going up steep hill and stronger vibration felt when flooring the gas om the free way aka high way aka interstate.
    Car is 2013 with just over 43,000km. Dr prius app shows good battery life. Everything on the car is stock with original parts such as spark plugs ignition coils and fuel pump. I'm going to stick a K&N air filter in soon.
    I've noticed something odd with the car when you open the driver door in the moring. The fuel pump runs really long compared to other cars I've owned. Other car fuel pump stop before I could even jump in but this prius C will keep running until I close the door and then some.
    I'm thinking maybe the knocks are linked to this symptom?
  2. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    I timed the fuel pump run time was approximately 10sec. My other cars were under 5sec.
  3. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    I'm slowly thinking its a engine mount or transmission mount problem. Going over rough bumps i get a knock. Also going up bumpy hills too.
  4. John in Vermont
    John in Vermont Junior Member
    50
    22
    Rochester, Vermont
    2018 Prius c
    The pump you hear when you get in the car is a vacuum pump charging the brake system, it is normal.
  5. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Great John thanks for the reply. How about the knock, still trying to figure it out.
  6. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Guys how do i check the engine mount structural integrity? My guess is that one for now. The reason i eliminated fuel pump, injectors and plugs is I'm having food fuel economy. And this noise only happens on bumpy roads while accelerating like up ac ramp or merging onto freeway. When its a smooth road i don't get any knocking noise.
  7. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    Is the knock in the front or back? Does it happen at idle or only when moving?
  8. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Knock in the front, only when moving.
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Who's there?
    wildgatsby, joelg1988 and Raytheeagle like this.
  10. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Hi John,
    Is it normal to keep hearing that pump for the brakes regularly when you drive and use the breaks?
    It comes on for 2 sec when ever i come to a stop or use the brakes during driving. Sometimes not but mostly it does come on when i drive.
  11. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    I think I've located the noise. My strut tower and the body of the car there is a gap( don't know if that's normal) or its time to get a new ones fitted or to tight it down. So when i wobble the car there is play in the strut and body. When i accelerate the weight of the car falls on the rear wheels so any bumps on the road will let the strut top bounce back and forth hitting the body causing the knock.
    Is it a easy fix? Do people also have gap between the strut top and the body?
    On my old Ford Ka my mechanic took off the strut top and trimmed it a little making it fit tightly to the body to eliminate the noise. I'm wondering if i should do the same here or I just need to tighten something down or put some o-rings in between the space...
  12. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    So here is a photographic view of my situation. I have a gap from my top support to the base on the body. World the problem be fixed if i screw down the nut? I thought those nuts were fit tight, in this case meaning my lower seat has flattened from age? Or can i put orings between the top mount and the body to take up the slack?
  13. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    Is it normal to be a gap here on a prius C? 2013
  14. Royston.K
    Royston.K Member
    75
    60
    Singapore
    Not on mine. I guess you found your culprit.
  15. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    It seems the gap shouldn't be there. My is still making some noise, but I can live with it.
    It stays silent most of the time. Just when accelerating slowly up a hill it will sound when it goes over a bump.
    But regular driving and with speed above a specific threshold, I guess the stress between parts just stops it from having that free play in between.
    Anyways I rest my case on this one. What i should have done is gone for a brand new set may it OEM or aftermarket and get them to trouble shoot it for me.
