Knock Sensor p0327, p0328 Check Engine Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yurtdweller, Jan 30, 2017.
  1. yurtdweller
    yurtdweller New Member
    Howdy folks.
    My Check engine light came on the other day. Engine ran poorly when climbing a hill. Sort of surging. (may be a red herring)
    Trouble code p0327 (Knock Sensor 1 Circuit Low Input) came upon scanning.
    I replaced the knock sensor, and now I get p0327 and p0328 (Knock Sensor 1 Circuit High Input)
    Any help in clearing this up is appreciated.
    Can I drive it without damaging anything?
    Thanks in advance.
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    What scanner did you use to read the codes?
  3. MAGARIVAR
    MAGARIVAR New Member
    San Francisco Bay Are
    2002 Prius
    I've got 2 codes. one is 3000H/12288
    the other one is P3009
    does anyone know about these codes and how do I post a question? I just signed up but do not see where I should post a new question, thank you for explaining n detail how I should do that...
    when trying to isolate the problem it only comes up when the engine is ON / ready and in Neutral Gear but does not come up if I just start the ignition (before cracking the engine, no codes)... so what seams to be the problem?
    #3 MAGARIVAR, Jan 30, 2017
  4. yurtdweller
    #4 yurtdweller, Jan 30, 2017
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That will read obd codes but not hybrid codes.
    If knock sensor engaged it means it's sensing a knock. We are seeing a lot of Prius lately with engine damage caused by high mileage poorly maintained oil levels. Many high mileage Prius eat oil and owners allowed to let oil go so low it damages main bearing or
    piston bearing.
    Engine bottom end is splashed lubricated. Low oil level no splash.
    If yellow engine light lit because of low oil I can almost guarantee you it has
    Been damaged.
    When knock sensor engaged it pulls engine timing and engine will have no power.
    Go on you tube look up Prius inspection mode
    That puts the car in continuous engine run. With engine on get under front of car and listen to engine for knocking or vibration.
  6. MAGARIVAR
    2002 Prius
    you can only if you wear eye protection and stay away from alcohol :) but kidding aside, its a good idea to invest in a toyota specific scan tool. some are expensive some not at all. I've seen a cable with a CD as low as $17 but you do need a laptop preferably with XP on it. That's what the pro's recommend. Then you can get an accurate reading of codes that relate to hybrid system. Good luck!
  7. yurtdweller
    If this is the case, a motor swap is in the future, correct?
  8. andrewclaus
    993
    326
    Golden, CO
    That's probably correct, but is this the case? Is your engine high mileage, with some oil-burning issues, and perhaps not perfectly maintained?
    If you've been diligent about maintenance, maybe you do have a more complicated emissions or engine control issue, and a Mini-VCI and laptop will help diagnose it correctly.
  9. MAGARIVAR
    2002 Prius
    keep the motor change the body..
  10. yurtdweller
    Here's an observation :
    When I erase the code, the check engine light returns immediately. Less than 1 second.
    I feel like if there was a problem with knock, it would at least wait to run diagnostic.
  11. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Why have you change knok sensor...did you inspect ignition ..spark plug ...fuel delivery..injectors...timing marks before you have engaged to replace knok sensor
    Another reason could be fuel quality...that will trigger knok sensor....
    Don't just start changing things till you are definitely sure you have sensor issue....eliminate all causes that will trigger knok sensor first
  12. yurtdweller
    I checked the web for answers on how to proceed. This was what I found:
    Common Causes of P0327
    To sum things up, the common causes for code P0327 are as follows:
    • Failed knock sensor
    • Fault in the knock sensor circuit
    • Failed PCM
    Before I swapped out the sensor, I got just one code p0327. After changing the sensor, I get two codes. p0327 (low input voltage) and p0328 (high input voltage). I am thinking that the new sensor is defective.
    When I erase the code, the CEL light comes back on immediately. (within one second). I believe that is telling me that there is a problem with the sensor, not a knock, as there does not seem to be enough time to perform a test, and because the light will return even while the gas motor is not running.
  13. andrewclaus
    993
    326
    Golden, CO
    I think your reasoning is okay. If the knock sensor is working and senses knocks, it doesn't give a code, it attempts to correct the knock with ignition timing, etc. I think the code is just to supervise the circuit, as you've deduced.
    Is it hard replacing the sensor? It looks like it's under the intake manifold. Did you get an OEM sensor?
  14. yurtdweller
    Thank you for the reply, Andrew. No need to panic when a sensor circuit fails.
    To get to the sensor, move the air box out of the way. 2 10mm bolts up top, one 10mm bolthead hose clamp underneath.
    The sensor is behind the intake. 12 mm bolt with tight quarters. I removed a bolt on the intake manifold to allow I little more space. I also had to bend a 12mm box Wrench to get any travel on the Wrench. Once broken free, I was able to get one finger tip on the nut and spin it tiny bits at a time. When it was backed out a bit, I could get a socket and wobbly on there, just not fully engaged.
    Very scared to lose the nut.
    I found I could reach up from below with my left arm under the intake. Not a procedure for the claustrophobic.
    Paul Schenck likes this.
  15. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    This is an example of why I HATE code readers and the technicians that use them to fix everything... :mad:
    P0327 is a CIRCUIT code, essentially the input VOLTAGE is LOW
    P0328 is also a CIRCUIT code, essentially the input VOLTAGE is HIGH
    Engine knock codes are: P0301, 2, 3, 4, last digit is the cylinder number
    Additionally, if you are getting pre-ignition/engine knock/misfires the check engine lamp should be FLASHING
  16. yurtdweller
    Replaced knock sensor with cheapo ebay, CEL persisted. Replaced el cheapo with Denso and walla! CEL is gone.
    Aaron Vitolins likes this.
  17. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I don't think Toyota engineers are that dumb to put splash lube on one of the most sophisticated cars that they designed. That's why there is a lower mark on the dip stick and a higher one. Keep within those marks you are good.
  18. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I better wait and put a fresh tank of detergent gas in before I replace it I suppose
    iPhone ?
    #18 Paul Schenck, Oct 2, 2019
