Knock sound at stops
Discussion in 'Generation 1 Prius Discussion' started by Nelsonprius, Jun 2, 2020.
  1. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    As I come to a complete stop braking there is a single or double knock every time in the last 12'. Mechanic, specialist in suspension and braking can repeat sound but not find it's source. Anyone else have this happen and find cause?
  2. Josey
    Josey Active Member
    300
    115
    Virginia
    2003 Prius
    Presumably the specialist person - or you - inspected and double checked the torque on the caliper brackets and slide pins? Perhaps even removing bracket bolts and pins to inspect them? And pulled the drums from the rear to inspect and make sure they're adjusted?
  3. Nelsonprius
    72
    Nelson, BC Canada
    2001 Prius
    I
    Yes the sound comes from the front of the car, and front brakes were fully inspected
